H&R with KYB AGX for civic fits integra???
my buddy has a set of these H&R race springs with KYB AGX that he's gonna give me if i want them. he drives a 98 civic hatch and i got a 94 GSR. will the suspension for the civic fit the integra? all constructive comments welcome. thanks.
I swapped my 95 civic suspension to my 01 teg. It's fine. AGX's and custom coilovers. If anything, check what the LCA's from your civic (rear) and see if they match up to the ones on the integ.
The fronts will fit without a problem, but you will notice that the 98 Civic rear shocks will have a narrower fork, I think most people just shave a bit off of the bushing and it will eventually fit over the Integras wider LCA bushing.
92-95 Civic and 94-01 Integra shocks (except ITR) are exactly the same. 96-00 Civic is slightly different because of the rear forks.
As stated above, the fork on the rears is a different size, not sure if there is any way you can work around it, the best bet would be to buy the correct part for your application.
Xerxes3333
Mar 26, 2004 01:05 PM
