Someone diagnose my problem please! weird noise. B18C1 *VIDEO*
http://www.nok7.com/noise.avi
in the video i'm adjusting the distributor and the TPS sensor to change the tone of the noise. If I had a light and voltmeter those would be set and i wouldnt be tinkering with them.. but since I don't and theyre not set they are great for changing the tone.
note. b18c1 swap into EH3.
possibilities,...
pinging.. since i have a LOT of 87 octane.. with a bottle of 108 octane booster. I think tomarrow would be a good day to buy some premium and pour it in.
knocking? I sure hope not... it is louder from under the car??
My uncle thinks its some exhaust leak... since i have no gasket on the 2 peice stock manifold seam and the manifold/cat isn't very tight...
or maybe something is just flapping...
or the valves.. oh god no not the valves!
someone help me =[ =[
note: it wasnt allways like this.. this started today. I don't even drive the car, its still on jackstands, I was messing with my throttle bodies (had strange TPS codes) and then the noise started)
possibilities,...
it could be a leak. lol at first I though you were cranking away on the engine until I realized that the engine is already running. definitely sounds like the sound is coming from that back of the engine. You got a leak somewhere or something is rubbing againste something. I'm quite sure. I recommend you get the intake manifold gasket fixed and cat converter tighten up first. otherwise you will be running in circles trying to find the problem.
lazynok
Jan 24, 2005 05:22 PM
