Suspension & Brakes Theory, alignment, spring rates....
*HELP* Integra Suspension Problem
Old Jan 21, 2005 | 05:36 PM
T.A.M.'s Avatar
Default *HELP* Integra Suspension Problem
I installed skunk 2 coilovers with Brand X lower control arms on my integra today. When the car gets over 60 it gets realy twitchy. I can bearly move the stearing wheel and the car jumps over a lane. I was told because the lower arms are 1 1/2 inches short that it may be throughing off the geometics of the rear. Let me know if anyone knows how to fix this. Will a rear camber kit fix this problem??? Thanks for the help yall.
Old Jan 21, 2005 | 05:39 PM
MattP's Avatar
Default Re: *HELP* Integra Suspension Problem (T.A.M.)
Did you get an alignment?
Old Jan 21, 2005 | 06:17 PM
T.A.M.'s Avatar
Default Re: *HELP* Integra Suspension Problem (MattP)
I've lowered 20 or so cars in the few years I've been working on cars and never had this problem before........ no alinment on anyof them and they were fine. ????
Old Jan 22, 2005 | 09:22 AM
T.A.M.'s Avatar
*** Bump ***
Old Jan 22, 2005 | 09:38 AM
CRX Lee's Avatar
Default Re: (T.A.M.)
Check your alignment, specifically check the front and rear toe settings as this will always change to some degree on a Honda when you change the ride height. Consider it mandatory. It did change on other cars you have done, you just may not have noticed the effect as much as this time.
Old Jan 22, 2005 | 10:01 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
get the rear alignment settings checked out. It`s your LCA's that are the problem.
Old Jan 22, 2005 | 12:02 PM
MugenRacerX's Avatar
*If you have the lca that is a inch or so shorter than that part must be used with the upper arm that is a inch or so shorter as well.
Old Jan 22, 2005 | 04:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (MugenRacerX)
The idea of aftermarket LCAs being shorter than stock has ALWAYS botherd me. Yeah it MAY help with a slight camber issue, but added negative camber isn't a bad thing (unless it's a drag car). Also, I'm sure this will negativly effect bump steer (which sounds like what your experiencing).
Yeah they may weigh less, but the bushing quality is always lacking, and only half of the wieght your droping is "unsprung" (because half the LCA is connected to the chassis).
Ditch those Brand X LCAs & swap in some used GSRs (or civics if its an EK).
Old Jan 23, 2005 | 08:09 PM
T.A.M.'s Avatar
Thanks for the info everyone.
unrestrictedkc
Dec 20, 2012 04:00 PM
passwordjdm
May 17, 2012 10:49 AM
m1am1sf1n3st
Jan 27, 2010 01:48 PM
Midori Green
May 4, 2008 03:02 PM
vib
Oct 20, 2006 06:37 PM
