Motor Mount busted?
Old Jan 21, 2005 | 02:36 PM
LiL accORd RideR's Avatar
Default Motor Mount busted?
Ok...a few weeks ago, i inquired on HT about shaking when i reverse my car. I finally took some pictures of the front mount. What can you guys say about this? is it busted, or just loose? and if its loose, is it an easy fix (just by tightening with a socket wrench)?
Old Jan 21, 2005 | 03:08 PM
D21X's Avatar
Default Re: Motor Mount busted? (LiL accORd RideR)
looks fine to me. u might wanna checkout the rear tranny mount.
Old Jan 21, 2005 | 03:15 PM
Accordman's Avatar
Have someone put the car in drive and than reverse. Back and forth slowwwly. Monitor how much the engine is moving at the mount. If the engine is rocking a bunch 1-2 inches or more, you have a bad mount. There are 4 mounts. The one in front and back are typically the first to go due to the torque put against them.
Looking at the pictures, the first seems to have something irregular in that it appears the rubber mount is not tight against the right side of the bracket. It also appears that the right side of the bracket may be bent. The rubber mount should be tight up against both sides of the bracket. You can try to tighten the bolt (nut the nut as it is mechanically captured with a metal hook) to see if you can draw it up against the mount.
JDM-EJ1
Aug 1, 2005 12:10 PM
TurboTagTeam
11
Dec 24, 2004 12:00 PM
hothotpete
Nov 22, 2004 11:12 PM
mattL
May 25, 2004 12:32 PM
CIVIX
Mar 18, 2002 06:03 AM
