FS: a multitude of parts
Old Jan 12, 2002 | 12:01 PM
TurboT's Avatar
Default FS: a multitude of parts
ITR stock parts:
-ITR flywheel used, 3k miles - $125
GSR stock parts:
-94-00 Integra engine lower mount, part #50841-ST7-Z00 - $20
-00 GSR b18c1 purge valve solenoid - $40
-00 GSR A/C bracket assembly with mount - $75
-98 GSR b18c1 stock spark plug wire set - $40
-98 Acura Integra stock springs - $40
-94-00 Integra Evaporator assembly - $150
-94-00 Integra A/C compressor with clutch assembly - $50
-94-00 Integra condensor with mounting rail - $50
-94-00 Integra dryer with bracket and bolts - $20
-94-00 Integra A/C fan - $30
-98 GSR hydrolic clutch piston, hardline, and flex hose - $50
-98 Integra front end package, hood, bumper cover (grilled for intercooler), fenders, head lights, clear front lights, hold down bar, front support assembly, all painted yellow, WW front lip, and all hardware - $600
-98 Integra steering wheel, leather wrapped, airbag, with cruise control equipment (switch, harness, control module, control unit, cable, pedal hinge) - $600
-98 Integra front bumper amber turn lights - $20
Civic Si stock parts:
-00 si b16a2 head bolts - $30
-00 Si b16a2 stock cams with stock gears - $75
Turbo stuff:
-TurboXS High Performance Manual Boost Controller - $70
-Pro Drive billet oil pump gear, brand new - $190
-Miscilaneous silicon turbo hose coupling -
-T-bolt hose clamps -
-LS tranny final gear - $75
Electronics:
-DEI remote window roll up and roll down control system - $75
-Integra Type-R stock radio with security code (lights up amber) - $125
-J&S Ultra Safeguard Version 2 with dual monitor, complete - $450
Others:
-Sparco footrest, for BMWs, anodized red, brand new - $25
-Reinforced hood locking system - $30
-Burton 156cm Charger snowboard, 2000 model, used once - $175
Old Jan 12, 2002 | 05:27 PM
TurboT's Avatar
Default Re: FS: a multitude of parts (TurboT)
ttt
Old Jan 20, 2002 | 04:50 PM
jetdriven's Avatar
is the ac fan motor the same as my 91 GS teg? I have the blade and shroud, i just need the motor. it looks like a pancake style and has Matua on the blade. if so then i want it.
jetdriven@aol.com
Old Jan 20, 2002 | 05:00 PM
mattL's Avatar
which engine mount are you selling? left right,etc?
serr38
Apr 27, 2014 10:22 AM
Frito1
Mar 19, 2003 08:36 AM
TurboT
Feb 26, 2002 03:19 PM
TurboT
Feb 18, 2002 07:46 AM
