White Noise ( scary )
Old Jan 21, 2005 | 10:24 AM
CRX_Control's Avatar
Default White Noise ( scary )
so im driving down a street and i notice that my car is making a funny noise by the transmission side. What i know right now is that it makes like this scraping noise, like when your breaking(and sometimes its like a spring on a matress) , this only happens at 2500-4000 rpms. Iv been trying to figure out what it was for a while now. Then after 2-3 days with this problem it starts to make the noise at 2000 rpms(its getting worse).but when i press the clutch down , all the noise goes away,so it couldnt be the breaks. Can it possibly be the clutch?im worried and a bit scared of what is going on . Does anyone have a good idea of what happened to my car?
Old Jan 21, 2005 | 10:35 AM
EL Vap133's Avatar
Default Re: White Noise (CRX_Control)
It might be the "main input shaft bearing" that is pretty common to go out on the 96-00 trannys. My 97 civic has gone through 2 of them already.
Old Jan 21, 2005 | 10:40 AM
Default Re: White Noise (EL Vap133)
how much do you think one whould cost?
Old Jan 21, 2005 | 10:44 AM
B2FiNiTY's Avatar
It is not that expensive but rather the labor it takes to replace it.
Old Jan 21, 2005 | 11:35 AM
Default Re: White Noise (B2FiNiTY)
ima be replacing it, does anyone know if i can use my 88 hf main input shaft bearing for my 88 si main input shaft bearing without a problem.
Old Jan 21, 2005 | 11:51 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_Control &raquo;</TD></TR><TR><TD CLASS="quote">ima be replacing it, does anyone know if i can use my 88 hf main input shaft bearing for my 88 si main input shaft bearing without a problem.</TD></TR></TABLE>
Just buy a new one cheapskate, it's about less than $20....
kenskii
Jul 8, 2014 08:33 PM
dj_justice
Jun 4, 2013 09:42 AM
EKBEAMIN
Transmission & Drivetrain
Feb 11, 2012 08:35 AM
typeee
Nov 21, 2003 01:05 PM
