Wierd ticking when im on the gas, bad throttle response
Heres my setup before I say anything
00 gsr
skunk2 intake manifold
stock airbox, itr intake arm
skunk2 stage 1 cams
skunk2 cam gears, +1 intake/+2 exhaust
jdm 4-1 header
test pipe
buddy club spec 2
fpr set at 48 psi
ih8ricerz gsr all motor chip
i just put in my cams yesterday, and put in some settings that my friends used with the exact same setup. The buddy club exhaust is naturally super loud, but theres this wierd ticking noise when I gas it at all rpms. The throttle response is also horrible, I can be lightly on the gas and not go anywhere. I did my own valve adjustment, pretty sure I did it right.
the exhaust is like a ticking and fluttering noise
its normal when i rev it up in neutral
What could be the problem? Thank you all in advanced
here the picture that lured u in here
Modified by milano2kdc2 at 7:06 PM 1/21/2005
Modified by milano2kdc2 at 8:08 PM 1/21/2005
00 gsr
skunk2 stage 1 cams
jdm 4-1 header
test pipe
buddy club spec 2
fpr set at 48 psi
Don't know what the problem is, but I just wanted to say your car is sick. Might want to get it to a shop and tuned instead of using your friend's settings.
civic402lx
May 10, 2008 08:33 PM
milano2kdc2
Jan 23, 2005 06:33 AM
