??mm is the 2nd O2 sensor
Old Jan 12, 2002 | 09:28 AM
Dan's Avatar
Dan
Default ??mm is the 2nd O2 sensor
how many mm is the 2nd O2 sensor on the cat?
Old Jan 12, 2002 | 09:33 AM
RacerXI's Avatar
Default Re: ??mm is the 2nd O2 sensor (ITR 1413)
I ended up dropping that section of the exhaust and using vice grips. It sucks too cause the wire is only so long. HTH. They also make an o2 socket, but i've never used one.
Old Jan 12, 2002 | 09:35 AM
Dan's Avatar
Dan
Default Re: ??mm is the 2nd O2 sensor (RacerXI)
yep it sucks work on it. Trying to change my cat , cuz only getting 123 WHP and dropping. Cat has some odd discoloring on the bottom.
Old Jan 12, 2002 | 09:53 AM
Dan's Avatar
Dan
Well I tried a 19mm and still too small. I'll try a 20mm Sucks not having the right size tools.
Old Jan 12, 2002 | 09:58 AM
EPGONZALEZ's Avatar
i use a 7/8 O2 socket...but sometimes its hard to reach..i also use wrench for O2 sensors ...looks like a tubing wrench...but has a swivel head
Old Jan 12, 2002 | 12:22 PM
Dan's Avatar
Dan
Default Re: ??mm is the 2nd O2 sensor (EPGONZALEZ)
Well its 22mm's
beastman@
May 19, 2008 08:39 PM
pizzamanprelude
Aug 2, 2006 03:26 PM
1998teg
May 20, 2005 05:25 AM
smkngsr
Apr 6, 2005 01:58 PM
