How to tell what AXEL is going bad..
Whatts up, i replaced the pass. side axel w/ a reman. one from Kragen and the driver side one looks like it would need replacing soon. You never know that the reman. could be the one ******* up.
Is there a way to tell which axel is bad when you make a left or right turn? I forgot what direction im turning when i hear the clicking, but ill find out soon. TIA Any info. is aprreciated
jack up the car and look to see if which boot is broken and that may lead you to the problem side or. the next time you take her out for a spin turn both ways and remember which side the noise is coming from also double check all the bolts on the bottom side maybe you forgot to tighten the axel nuts all the way
The Collin
Oct 24, 2008 04:27 PM
stockegsix
May 27, 2004 04:52 AM
