DA wheel Vibration-Please help
I have a 90 2dr integra ls 5spd. When I accelerate the car vibrates. Its coming from the right side. I replaced the axel (it needed it regardless) but that didn't fix it.I check the tires and even rotated them. I had got an alignment done but that did not correct the problem. One thing I did notice was the front tranny mount (bolts to the front crossmember) is torn and just about shot, I didn't think that could cause so much vibration. Any ideas on what it could be? Please help, this is getting aggravating. thanks in advance
had the same problem. ended up being my front crossmember. 2 trips to the junkyard and $300 later i had new front crossmember, whole new suspension on the passenger side, and no shakes.
Bad tranny bearings cause it to vibrate too... even if park the car and rev you can feel it...is a very common problem.... i have a 92 gsr and i have that problem....i bought another tranny that i`m rebiulding....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacura »</TD></TR><TR><TD CLASS="quote">had the same problem. ended up being my front crossmember. 2 trips to the junkyard and $300 later i had new front crossmember, whole new suspension on the passenger side, and no shakes.</TD></TR></TABLE>
How did you determine that? Thanks
Regal
13
Mar 20, 2008 12:49 AM
.nate
Jul 10, 2002 06:21 PM
