rad fitment?????
Old Jan 20, 2005 | 07:28 PM
plastik462003's Avatar
Default rad fitment?????
will a 90-92 integra rad fit in my 91 si hatch, along with the si fan? also is this a bolt on install. or do i have to modify anything thanks josh
i did do a search, nothing helped
Old Jan 20, 2005 | 07:33 PM
EP3_05's Avatar
Default Re: rad fitment????? (plastik462003)
I believe the integra radiator is longer than the stock one and needs to be modded to fit. Why not just go with a stock radiator? Do you really need the extra cooling capacity?
crexer's Avatar
YES this will work. I just dropped in a 92 gsr radiator the other day into my crx and it fit like a glove and its dual core!! Im not currently using any fans but there was plenty of room for a fan and as for the fan mounting just bend a peice of metal and theres your bracket. But its basically just a drop in deal. 150% sure this will work. Dont listen to others who have not personally done it. And it also has bigger inlets for the B series radiator hoses
Old Jan 20, 2005 | 07:40 PM
Default Re: rad fitment????? (crexer)
i'v read your post in the other question about this and i'm having the same problem u did with the bottom hose on my b16. so there is no mounts on the rad for the fan to bolt up to what if i get the fan from the teg?
Old Jan 20, 2005 | 07:46 PM
crexer's Avatar
ok i just checked it out and the fan is held on by 2 10mm bolts at the top of the radiator and it looks like the DA and the crx radiator both have the 2 mounting points in the same spot for the fan. The fan should bolt right up but I said screw it since its dual core who needs a fan lol.
Old Jan 21, 2005 | 05:39 AM
PRS395's Avatar
Yes, the 91-93 integra radiator will fit in the 88-91 hatch. Virtually the same radiator except couple of the fan mounts are a little off.
The lower fan mounts that don't line up, don't worry, it is still secure enough.
You can still use both stock fans with air conditioning, if you want to.
anastomosis
Jul 5, 2010 04:57 PM
B20luda
Jul 1, 2008 09:38 PM
bwco
Apr 3, 2008 04:13 PM
stuie08
Jan 22, 2008 01:10 PM
Etylorcen
Aug 15, 2002 08:21 PM
