eg front *springs* on ef?
Old Jan 20, 2005 | 02:02 PM
dlric's Avatar
Default eg front *springs* on ef?
i wish i had a pic of it, but i just put DA front knuckles and eg stock shocks/springs on my 88 hf. all i have to say is......this car looks like it just came back from a rally. i haven't measured the space between the top of the front tire and the fender but my guess is it's 8+inches or higher.
it kind of looks like yea...i put a lift kit on my crx.
i know DA knuckles have been used on ef's. i used brand new ef uca's. i replaced the lower balljoints with new DA balljoints. i then used stock shocks/springs/forks from a 94 eg.
should i put ef springs on the eg shocks? is that the story here? i haven't measured the differences in spring height as i have not had 2 side by side. i figured the crx might be an inch or two higher but this is ridiculas.
thanks for input
Old Jan 20, 2005 | 02:14 PM
elmalouno's Avatar
Default Re: eg front *springs* on ef? (dlric)
http://www.ef-honda.com/ben/EFhybridsus.php
this should help
Old Jan 20, 2005 | 02:34 PM
Tyson's Avatar
Default Re: eg front *springs* on ef? (elmalouno)
thats some pretty interesting stuff about fitting EG forks over the lower bracket of a stock shock to get more shock travel.
usually, you break off the whole collar and slip it in further. but that takes a bit of fabrication. all you need apparently is EG forks.... :thinking:
Mr. DeOro
Suspension & Brakes
Aug 6, 2010 06:07 AM
Metal Head
Suspension & Brakes
Nov 25, 2006 09:57 AM
gribbs
Apr 5, 2003 03:51 PM
