Installing GSR LCA's & RSB on my EG hatch...what hardware do I need?
I've got a '94 Civic hatch and am installing a set of a/m springs & shocks along with the LCA's, endlinks, and RSB from a '97 GSR.
However, I don't have all the bolts for the RSB.
There is this kit available from J.C. Whitney...is this all I'll need?
http://hybrid2.honda-perf.org/...a.jpg
Any help is appreciated.
i know its a little off but dont forget the pb blaster.
you have the endlinks and everything right? and the brackets for the d brackets?
Yup, I've already done 2 applications of PBB to all key bolts and such.
Yes, I have the LCA's and the endlinks from the GSR.
D-brackets? They come in that JCW kit, right?
Shouldn't there also be bolts that connect the ends of the RSB to the LCA?
the jcw is the d brackets and yea youll need bolts for the endlinks to go to the lcas. but i think theres also a bracket that goes between the d bracket and the subframe. somebody correct me if im wrong.
You will also need #12 (quantity 1) & #13 (quantity 1), #42 (quantity 4), and #27 (quantity 4). Your chassis doesn't have the nuts welded inside the sway mount holes, so you will need nuts & washers for the backs of all #42s. Instead of purchasing number 42s from honda, go to lows & buy some short 10 or 12mm bolts, lock nuts & washers. Make sure the bolts are standard grade 8 (metric grade 10.9) or better. Grade 8 is the best for standard bolts, and grade 12.2 is the best for Metric. You should buy the honda #27s though.
Get them from Acura Here...
The JCW kit comes with #7 & #10 (2 of each), but make sure it is for a 14mm bar, otherwise just get the ones from the Acura page too.
ek9tl
Aug 20, 2007 04:35 PM
