Burning Oil GSR
Old Jan 20, 2005 | 12:32 PM
joshalee's Avatar
Default Burning Oil GSR
I just wanted to know people's thoughts on this:
I did a test on my GSR oil. I have castrol gtx 5w30 and went from the top level of the dipstick to the low level after 250 miles. I have a header and exhaust. I engage VTEC normally and shift around 4500-5000 rpms
Should I try another type of oil?
Old Jan 20, 2005 | 12:51 PM
redGSRguy's Avatar
Default Re: Burning Oil GSR (joshalee)
You can try another oil, but if it burns that fast you might want to get it checked out. I pretty much have to give my car ~1/2 a quart of oil every fill up. I got a compression test done and cylinder 2 was low. I'll just live with it until I have money to fix my car.
Old Jan 20, 2005 | 12:58 PM
vidanator's Avatar
yes my gsr also burns quite a lot of oil, i still gotta get around to do a compression test, but yeah i prob won't be getting anything done till winters over, i was also wondering what could cause for so much oil burning
Old Jan 20, 2005 | 01:02 PM
rough_draft's Avatar
how many miles are on your car? You could try replacing the valve stems.
Old Jan 20, 2005 | 02:42 PM
joshalee's Avatar
Default Re: (That vodka That Sprite)
So here's the thing: The dealer completely rebuilt my head back in September from 2 bad cylinders. It's a 98 and has 55K miles on it. I decided for them to fix it cuz back then I only had 50K miles.
Old Jan 20, 2005 | 02:52 PM
phantom grey eg's Avatar
Default Re: (joshalee)
Any Honda/Acura that is reved to 7-8+ rpm's is going to burn oil, unfortunetly thats the trade off to honda's high reving engines
Old Jan 20, 2005 | 04:33 PM
JustROLLIN's Avatar
Could be any number of reasons for burning oil. Valve stems seals could be bad, if the system was overfilled, PCV issues, plugged oil return holes in the head, worn piston rings, and more I have forgotten.
Old Jan 20, 2005 | 04:35 PM
JustROLLIN's Avatar
Different oil will not help the issue you are having. I would have someone do a compression check and leakdown test if you really want to know the condition of your engine.
Also, the statement above about high-revving engines is true. Any engine that spends time up in the 7-8k rpm range will burn some oil.
DOHCgarage919
Sep 17, 2012 11:33 PM
sinister357
Aug 21, 2007 03:26 PM
vtec8804
May 31, 2007 09:24 AM
HoUTX98GSR
Jun 16, 2005 06:47 PM
