JDM Light Wiring Question
Old Jan 11, 2002 | 11:35 PM
TypeR 508's Avatar
Default JDM QUESTION
Does anyone know how to wire the lights up for the like side blinkers and all that stuff or is there a websitre thnx!@!
Old Jan 11, 2002 | 11:51 PM
Mike M's Avatar
Founding Member
Default Re: JDM QUESTION (crashmase)
I've posted this many times but cant seem to find it in the Archives
As far as the Headlights depending on if its HID or NON HID you will either have a 5 pin plug or a 4 pin plug on your headlight (Brown Connector) Look in behind the connector and you can see the color of the wires in it.
Black is Ground
Green is City Light (Parking Light)
Pink is (+) For High Beam
Blue is Fog Lights - To wire up the Fog Lights Please View this Thread https://honda-tech.com/zerothread?id=105247
If you have the OEM HID then theres a 5th plug that has a white wire - Low Beam (+) If you Have NON HID then you just use the original connector and 9006 bulb in the housing.
The lights inside with the High beams and Sidemarkers (On fenders) should be on with the parking lights, Shouldnt flash. The Turn signals (outermost lights on the headlights will flash when turn signal or hazards are on.
On the USDM Turn signal there is a small bulb (168) with 2 wires and a Large bulb (1157) with 3 wires
Take the small one with 2 wires and extend that to the Side marker on each fender Plug it in and thats done.
Take the Large one with 3 wires
(1 wire is Ground, 1 is Parking light (+), and 1 is Turn Signal (Flash) (+))
The color of the Parking light wire on the 3 wire bulb is the same color wire that is on the 2 wire bulb, Cut that wire off of the 3 bulb connector so that it now only has 2 wires (A Ground and a Turn Signal (+))
Take the wire you cut (Parking signal) and run that to the City Light (Green wire) on the Headlights Brown connector.
Take the Large Bulb that now has 2 wires going to it and trim the "keys" a bit to make it fit into the JDM Turn Signals on the Headlights.
Thats about it, Good Luck
Mike
MILANO_RED_CL9
Acura TSX
Dec 8, 2010 05:01 AM
Junkie
Lighting
Sep 30, 2007 04:52 PM
[Ennis_D]
Jan 11, 2005 06:50 AM
stock92prelude
Aug 30, 2003 09:06 AM
