WILL IT RUN HELP ME OUT
Old Jan 20, 2005 | 09:57 AM
dozer1313's Avatar
Default WILL IT RUN HELP ME OUT
i swapped a SOCH ZC into my 99 civic the ZC is non vtec and the civic had a D16Y8 vtec engine (I also had to convert from obd2-b to obd2-a ZC engine is a 97)BUT my main problem is that the ZC's idle control speed censor has three wires to it and the civic's only has two.What do i do i still have the vtec engine the head is good also (the ZC is 1.5 the civic 1.6 will the head fit)and do i have to run vtec oil pressure line for the vtec head.Also will it run with the ICS censor disconnected.and do you know where on the ecu the extra wire go's.Or where i can find out
Old Jan 20, 2005 | 12:41 PM
jayspec22's Avatar
Default Re: WILL IT RUN HELP ME OUT (dozer1313)
are you sure its not a jdm d15b with vtec? i think* those motors are obd1
deeloo
Jun 18, 2016 10:02 AM
JdM_RACeR07
Oct 24, 2006 10:55 AM
dozer1313
Jan 19, 2005 02:17 PM
