Do ITR suspensions work on GSR's???
Old Jan 20, 2005 | 09:44 AM
peel17's Avatar
Default Do ITR suspensions work on GSR's???
Will ITR suspensions fit on GSR's???
Old Jan 20, 2005 | 09:57 AM
gsr squirrel's Avatar
New User
Default Re: Do ITR suspensions work on GSR's??? (peel17)
i'm pretty sure you just need ITR LCA's for the rears. everything will bolt right up to ur GSR.
https://honda-tech.com/zero...age=5
Old Jan 20, 2005 | 10:00 AM
SwedBoy2999's Avatar
If i have it on my 92 GS-R then i'm sure it will fit in you G3 GS-R. Just need the rear LCA's like previously stated. It's the only way for us G2 folks to get some more competitive suspension options.
Old Jan 20, 2005 | 10:07 AM
Mazinger's Avatar
I have a G3. Springs went on fine with no mods. Sway bar requires additional aftermarket brackets.
Old Jan 20, 2005 | 10:12 AM
peel17's Avatar
Default Re: Do ITR suspensions work on GSR's??? (Mazinger)
How's the ride compared to aftermarket lowering springs?
Old Jan 20, 2005 | 11:32 AM
Mazinger's Avatar
I've never had any other springs besides the OEM and the ITR one.
The ITR spring is much stiffer than stock and it only lowers it a little (which is what I wanted).
Old Jan 20, 2005 | 12:20 PM
vidanator's Avatar
by how much would u say the itr springs lowered ur car than previously because i've been thinking about using oem itr springs too because i don't want my car to be lowered that much because i get a lot of snow where i live, and do u have a ls or gsr?
Old Jan 20, 2005 | 12:21 PM
vidanator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazinger &raquo;</TD></TR><TR><TD CLASS="quote">I've never had any other springs besides the OEM and the ITR one.
The ITR spring is much stiffer than stock and it only lowers it a little (which is what I wanted).</TD></TR></TABLE>
Old Jan 20, 2005 | 12:51 PM
timmy8151's Avatar
Default Re: Do ITR suspensions work on GSR's??? (vidanator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vidanator &raquo;</TD></TR><TR><TD CLASS="quote">by how much would u say the itr springs lowered ur car than previously because i've been thinking about using oem itr springs too because i don't want my car to be lowered that much because i get a lot of snow where i live, and do u have a ls or gsr?</TD></TR></TABLE>
They lower your car about 0.5 inches.
Old Jan 20, 2005 | 01:12 PM
DC2 BoZz's Avatar
Default Re: Do ITR suspensions work on GSR's??? (timmy8151)
good info...but is the LCA the Lower Control Arms??? and i ******* hate snow...i got some now
Old Jan 20, 2005 | 01:46 PM
peel17's Avatar
Default Re: Do ITR suspensions work on GSR's??? (DC2 BoZz)
Will there be any camber wear since the ITR springs will be lowering it to .05???
Old Jan 20, 2005 | 02:25 PM
DC2 BoZz's Avatar
bump for NY/NJ
Old Jan 20, 2005 | 02:26 PM
FireMedic's Avatar
I have ITR springs on my 94 LS w/ 16" & 205-45-16... heres a picture. Rides really well... I've had many compliments on how it rides in relation to how low it is, even from my 57 year dad. Ignore the SUV if you don't like it Springs are a direct swap, no other parts needed. complete suspension is a different story of course.
Old Jan 20, 2005 | 02:30 PM
Moogen Powah's Avatar
Default Re: Do ITR suspensions work on GSR's??? (FireMedic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 BoZz &raquo;</TD></TR><TR><TD CLASS="quote">good info...but is the LCA the Lower Control Arms??? </TD></TR></TABLE>
Yes, LCA = Lower Control Arm
Old Jan 20, 2005 | 08:43 PM
DC2 BoZz's Avatar
Default Re: Do ITR suspensions work on GSR's??? (Moogen Powah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moogen Powah &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, LCA = Lower Control Arm</TD></TR></TABLE>
THANKS Just wanna be sure
Old Jan 20, 2005 | 08:48 PM
monkeyboy20's Avatar
Old Jan 21, 2005 | 10:09 AM
peel17's Avatar
hey, soo.. is there any camber kits that will correct the (ITR)55mm drop?
Old Jan 21, 2005 | 10:17 AM
B2FiNiTY's Avatar
You won't need a camber kit.
Old Jan 21, 2005 | 10:21 AM
timmy8151's Avatar
Default Re: Do ITR suspensions work on GSR's??? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">You won't need a camber kit. </TD></TR></TABLE>
I agree. Remember that it's toe that eats up tires not camber. My camber settings are -0.9 & -1.8 on my front tires and I haven't had any abnormal wear.
Old Jan 21, 2005 | 10:27 AM
peel17's Avatar
Okay just checking.. cuz i have a 92 DA sedan and had axle problems with a 1.5 and 1.8 rear drop.
I don't want to have axle problems with my DC with the ITR springs
Old Jan 21, 2005 | 01:06 PM
trellix78's Avatar
New User
Here's how ITR springs and shocks look on a 4-door GSR with ITR sway bar.
I'll post pics later of how the sway bar mounts with Comptech integral tie bar.
Old Jan 21, 2005 | 01:08 PM
peel17's Avatar
Default Re: Do ITR suspensions work on GSR's??? (trellix78)
picture ain't workin
Old Jan 21, 2005 | 01:21 PM
peel17's Avatar
thats a nice drop
Alloy
Suspension & Brakes
Jun 28, 2007 03:15 AM
UnionCity LS
Mar 5, 2003 02:58 PM
tekstyle
Nov 20, 2002 07:39 AM
Projected
Nov 10, 2002 04:09 PM
gsxr
Oct 17, 2001 07:25 PM
