window washer fluid???
Old Jan 19, 2005 | 09:36 PM
oscar_lopez03's Avatar
Default window washer fluid???
i didnt know anywhere else to put this, so i put it in the engine tech cuz this is part of the engine. i notice today that i dont have any lines running to the little window spuirter on the hood. so i go and look at the fluid container and there are no lines coming out of it. i was wtf then i kept looking around and i saw a hole on the side but still no lines. i need to know where those lines come from and how to install everything. do i need a fluid container? also does the motor come inside the fluid container or somewhere else. help me out so i can figure this out.
Old Jan 19, 2005 | 10:00 PM
Donkey85's Avatar
Default Re: window washer fluid??? (oscar_lopez03)
the washer pumps are connected to the outside of the solvent resivor the hoses connect to them and ran up to the squirters
Old Jan 19, 2005 | 10:06 PM
beerbongskickass's Avatar
Default Re: window washer fluid??? (Donkey85)
I ripped mine out so I could run charge piping. I never used the washer fluid anyways and when I did it never worked that well. I even live in the PNW where it rains all the time too.
Old Jan 19, 2005 | 10:17 PM
smokee's Avatar
Default Re: window washer fluid??? (beerbongskickass)
i never use it in the pac nw either, the rain is all the windsheild fluid you need :
sounds like you may be missing the pump, i would be looking for that. it makes a "pumping" noise when you hit the fluid button
Old Jan 20, 2005 | 08:22 AM
so if u run a turbo u need to get rid of it???
Old Jan 20, 2005 | 08:45 AM
snatch's Avatar
Default Re: (oscar_lopez03)
Not necessarily, could have just been his piping for the front mount intercooler.
Old Jan 20, 2005 | 08:48 AM
m3dia_lab's Avatar
you could always relocate it too...
TooManyTickets
30
Jul 16, 2007 09:45 PM
redDAinteg
Jan 4, 2007 01:53 PM
Thunder Cat
Dec 9, 2005 03:39 AM
k00lboarder4
Sep 3, 2005 11:33 AM
HanSnobbler
Jul 22, 2005 08:14 PM
