Apexi Power FC is burning my ecu fuse. Help
Old Jan 19, 2005 | 08:03 PM
rusteds2k's Avatar
Default Apexi Power FC is burning my ecu fuse. Help
I just purchased an Apexi Power Fc w/commander for obd1 Honda/Acura. My car is an OBD2 Gsr. I have a jumper harness so plugs right up. It runs fine with my Chipped p72 Ecu. But when I plug in the Power fc ecu, it turns on for a split second then the fuse burn out. I tried with my friend's obd1 gsr and it does it same thing. Can someone help me?
Old Jan 19, 2005 | 08:25 PM
TheShodan's Avatar
Moderator
Default Re: Apexi Power FC is burning my ecu fuse. Help (xaznxboixsirx)
It's because of the ECU you have. Do you have the B16B EK9 Power FC? That will make a difference. If you have the right ECU, doesn't matter even if the wiring harness is OBD2. It should plug right in...
Also. What map sensor do you have connected right now. If it is anything other than the Stock DENSO map sensor, it's not going to like it..
Old Jan 19, 2005 | 08:39 PM
rusteds2k's Avatar
Default Re: Apexi Power FC is burning my ecu fuse. Help (TheShodan)
The product number is 415 z002. It plugs right into any obd1 harness.
The one on the apexi website manual says 414-h001 is for 96-98 Civic and Integras.
Old Jan 19, 2005 | 08:44 PM
rusteds2k's Avatar
Nevermind. I got it to work. The fuse in my car wasn't strong enough. Thanks for the response though.
Modified by xaznxboixsirx at 7:45 PM 1/20/2005
Old Jan 20, 2005 | 06:00 AM
TheShodan's Avatar
Moderator
Default Re: (xaznxboixsirx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxboixsirx &raquo;</TD></TR><TR><TD CLASS="quote">UPDATE: Ahhh crap, I found out this ecu is for '95.12~'98.11 13B-REW FD3S. Damn it. I wonder if it would work on my honda with some modification? Please link me if you find any info.</TD></TR></TABLE>
No. You must have the HONDA ECU for it to work. You must also make sure that you have the right commander to go with it. If it is 414-H001, that should be the universal commander to go with the ECU, but you MUST have a Honda ECU in order for it to work.
STAKEN
Jan 15, 2012 12:41 PM
JDM00SI
Mar 29, 2006 10:35 PM
TBoDelSol
Dec 20, 2005 04:43 PM
Dyno Queen
Aug 26, 2003 07:35 PM
