1/4 miles ????
Old Jan 11, 2002 | 07:27 PM
JHew84's Avatar
Default 1/4 miles ????
i'd like to know some of the 1/4 mile times that preludes run, preferably the newer STOCK preludes... but i would also like to know what modded ludes run also...
thanks
Old Jan 12, 2002 | 05:16 AM
fierce's Avatar
Default Re: 1/4 miles ???? (JHew84)
With a g-tech I can get 14.8 pretty consistantly. Thats stock with an AEM intake on a 5th gen
Old Jan 12, 2002 | 07:31 AM
prelude1897's Avatar
I haven't taken mine to the track, but you should be running low 15's high 14's..Somewhere in there
Old Jan 12, 2002 | 07:33 AM
That G-tech things aren't really acurate. They don't tell you what you really run, cause they are off a little
Old Jan 12, 2002 | 07:38 AM
Sigma D's Avatar
Default Re: 1/4 miles ???? (prelude1897)
i "run" my 1/4 mile in under 4 minutes... (get it, run...nevermind)
but truthfully, i havent run my car yet. would like to see what i can get stock
Old Jan 12, 2002 | 09:12 AM
fierce's Avatar
The g-tech are only off by 1/10th, so if my g-tech says 14.8 it could be 14.9 or even 14.7
My friend used my g-tech and said the numbers it was giving him were just like what he had got at the track..
The 0-60 times for the g-tech are pretty much exact. All it does is count the time from when you go till your @ 60 mph.
Old Jan 12, 2002 | 12:29 PM
laughinxxx's Avatar
New User
Default Re: 1/4 miles ???? (fierce)
I ran a 15.7. I swear those blinking yellow lights messed me up.
Old Jan 12, 2002 | 01:01 PM
Turbo-Si's Avatar
whats the 1/4 on a stock 95 prelude si
Old Jan 12, 2002 | 01:05 PM
laughinxxx's Avatar
New User
Default Re: 1/4 miles ???? (Ludesi)
mid high 15s
Old Jan 12, 2002 | 02:18 PM
DJOwenXC's Avatar
the Vtec 4th Gens are faster then the 5th Gens stock in my opinion, it all depends on the driver of course, I have a 4th gen -80lbs with H22a 200hp and when I shift perfect have run a 14.1
[Modified by DJOwenXC, 6:20 PM 1/12/2002]
Old Jan 12, 2002 | 02:29 PM
illusion's Avatar
Default Re: 1/4 miles ???? (DJOwenXC)
14.1 wow.. even with 80lb reduction and jdm h22a.. thats still hard to believe. nice job though.
the staging lights shouldnt really matter in the 1/4 mile time. only the reaction time. you can sit at the lights for 5 secs after green.. and still run a 14s time.
gtech meter isnt *that* accurate. it all depends on the road. the flatter.. the more accurate as far as ive been told.
Old Jan 12, 2002 | 02:42 PM
BluLuder's Avatar
Default Re: 1/4 miles ???? (Jonesy69)
You aint runnin a 14.1 without LSD.
Even with my turbo'd Si Im hoping for times near that.
Old Jan 12, 2002 | 03:06 PM
DJOwenXC's Avatar
hey, whatever you choose to believe, all I know is that is what the Gtec pro told me, and I believe it's accurate enough, like said above it may be .1 to .2 off, but whatever
Old Jan 12, 2002 | 03:09 PM
laughinxxx's Avatar
New User
GTech numbers aren't timeslips. If you can race well at the drag strip you should have some nice times though.
Old Jan 12, 2002 | 03:15 PM
DJOwenXC's Avatar
Default Re: 1/4 miles ???? (illusion)
illusion's right, the flatter the surface your running on the more accurate it is, example: my friend with a 2001 ITR ran a 0-60 of 7.2 with the Gtec pro, but he was also on a hilly road with a fat 200lb girl in the passenger seat, if he's shifting right, with his mods and w/out the girl or hills, he should be runing 0-60 6 or 6.1 sec; he hasn't got a chance to run his 1/4 on it yet, but I could understand how much the hills could effect it the way it is made, it may be the reason it's saying 4.1 or 4.2 when I run, but again, I don't have any completley flat road around here either, just to be fair, I'll try to find a straight road that slightly hills upward or something, being there are no flat roads around here, I'll get back to ya'll in a little bit
Old Jan 12, 2002 | 03:33 PM
laughinxxx's Avatar
New User
Running at a drag strip is different from any other type of racing. You have bleachers full of people that extend half way down the track, you have a guy who justs wants to get you down the track and out of there ASAP running the lights, you have a helmet on that you practically suffocate in, you don't get practice runs, you have to wait an hour between each run, you have a 10 second car running next to you, you have a 30 second car running next to you, you have bracket classes with the other guy's lights dropping before yours. I mean I could go on all day. Personally I hated it, but I know that I'll have to go back to get a damn timeslip to show how fast my car is. Hopefully you don't believe that I run 15.7s on the streets, I just wasn't able to race at the track my first time there and managed to **** up 3 seperate runs. .
Old Jan 12, 2002 | 03:53 PM
Mike95lude's Avatar
Default Re: 1/4 miles ???? (Sigma D)
i would hope so...thats a 16 minute or less mile pace...which is about walking speed.
Old Jan 12, 2002 | 04:14 PM
illusion's Avatar
Default Re: 1/4 miles ???? (laughin2.2)
heh i dont believe your car is a 15.7 car. i was just joking with you and letting you know that the lights dont affect the e/t. i havent been to the track yet and im sure im gonna be nervous as **** my first time as well.
Old Jan 12, 2002 | 06:03 PM
blown'lude's Avatar
my stock 97 prelude did the 1/4 in 14.78 and after my mods and such
my best time has been 12.97
Old Jan 12, 2002 | 06:26 PM
fierce's Avatar
Default Re: 1/4 miles ???? (blown'lude)
on the g-tech it tells you if your flat or not, if your more than +10 or -10 (which is a very very slight hill, hardley noticable to the eye) it will not give you your time
Old Jan 13, 2002 | 04:15 PM
DJOwenXC's Avatar
yeah, with the Gtech you have to be pretty flat at the start, but once you start going it doesn't cancel it, or it hsn't for me anyway, I found a flatter surface to be more accurate last night, and I couldn't find any at stoplights, I went out at 3am last night and stopped in the middle of the road, it still had very slight hills but was pretty much flat, ran a 14.7 once, 14.9 twice, a 15 twice and a 15.1 once
Old Jan 13, 2002 | 04:19 PM
DJOwenXC's Avatar
yeah, I agree with laughin, it's exactly how he describes it, and a lot more, I've never run a 1/4 mile track, unfortunatly don't have one nearby, I'd have to drive to Atlanta, wich I'll be doing soon hopefully, but I have run at the the local 1/8th mile back when I was completly stock with my H23, ran a 9.95
Old Jan 13, 2002 | 07:51 PM
BY01LUDE's Avatar
I Figure that I will be in the low to mid 13's, next time I go out!
Old Jan 13, 2002 | 08:00 PM
mexicanlude83's Avatar
My personal best ET Time is 15.1 with my current mods.
Old Jan 13, 2002 | 08:38 PM
schwett's Avatar
New User
which pulley did you replace for 10psi? and what is your iat? must be off the chart.
