Seafoam killed my o2 sensor
Old Jan 19, 2005 | 06:56 PM
GSlowR's Avatar
Default Seafoam killed my o2 sensor
Well pre-seafoam my air/fuel gauge read perfectly..
post-seafoamage.. the thing doesn't work at all anymore.. sometimes works but most of the time has no lights coming on..
anyone else experience this or have any explanation as to what happened?
Old Jan 19, 2005 | 07:50 PM
timmy8151's Avatar
Default Re: Seafoam killed my o2 sensor (GSlowR)
Seafoam is a solvent and rapid cleans your engine. Most likely your sensor got fouled as a result of the seafoam. This is a common problem when using solvent based cleaners. That's why I prefer esther based cleaners because they work slower and are less likely to cause fouling.
Old Jan 20, 2005 | 01:53 PM
GSlowR's Avatar
Default Re: Seafoam killed my o2 sensor (timmy8151)
DAMMIT! i just changed that POS! i'll just have to have my car tuned open loop.. i'm tired of messing with that BS! AHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!
Old Jan 20, 2005 | 06:03 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
what is a good esther based cleaner? what do you use?
Old Jan 20, 2005 | 06:28 PM
timmy8151's Avatar
Default Re: (MugenDude)
I use Auto-Rx. It's not a cheap product, but it really works. I'm a firm believer in it.
You can read about it at: http://theoildrop.server101.com/cgi/ultimatebb.cgi
Order it from: http://www.auto-rx.com/index.html
JDM_SOHC
12
Mar 28, 2009 02:52 PM
GSlowR
Apr 15, 2005 11:20 PM
Trac226
May 8, 2003 11:40 AM
