How to identify a Type R head??
Old Jan 11, 2002 | 06:28 PM
LeftCorner's Avatar
Default How to identify a Type R head??
Are there any markings to tell if a head is actually from a Type R? Aren't the B16A, B17A and B18C5 heads all stamped PR3?
Old Jan 11, 2002 | 06:51 PM
bojangs's Avatar
New User
Default Re: How to identify a Type R head?? (LeftCorner)
yup, they're all stamped the same.. cams are one way to check but they can be swapped too easily.. the dead give away is the larger/lighter intake valves of the itr..
Old Jan 11, 2002 | 08:00 PM
sgT's Avatar
sgT
The front of the head is stamped PR3-X for all of them where X will be 1-4.
On the top by the distributor:
92+ heads are all stamped 30 for P30
90-91 heads are stamped 3 for PR3
To tell an itr head, you can look at the distributor arm on the head it will be
painted green. but if that has worn off, then you have to take the valves out
to check the seat blending.
Old Jan 12, 2002 | 01:04 PM
LeftCorner's Avatar
Default Is this one?
Any way to confirm this as an ITR head with only 7546 miles??
[Modified by LeftCorner, 2:06 PM 1/12/2002]
Old Jan 12, 2002 | 02:01 PM
Trey's Avatar
25 Year Member
Default Re: Is this one? (LeftCorner)
The only real way to be sure is to see if the green strip is on the intake side of the head where the dist bolts up. Look at the pic from C-Speed:
The regular B16a's don't have this........
Old Jan 13, 2002 | 03:00 PM
IntegraleEVO's Avatar
I supposed u saw this head for sale on ebay right?
Just a look out for you, he is using my pics.
Details here
http://www.hybridforum.net/showthrea...sb=5&o=2&part=
-david
Old Jan 13, 2002 | 03:49 PM
LeftCorner's Avatar
Yup, that's exactly where I got those pictures from. And if you want to do something you can report them to SafeHarbor and they'll take the appropriate action. But there's less than a day left on it so I dunno if you want to pursue anything. BTW, I quit bidding on it because that head looks like it has more than 7500 miles on it and the seller doesn't have any other pics. Interesting . . .
crxvtecturbo
May 10, 2014 05:12 PM
mynameizstitch
Apr 8, 2013 07:43 PM
hondacando
Jul 31, 2010 03:00 PM
TurboEM1
Dec 26, 2009 07:50 PM
92TypeR
Mar 25, 2002 05:39 PM
