what is an easy swap for my cb7(92 accordlx) and i did search
Old Jan 19, 2005 | 05:07 PM
hatchinprogress's Avatar
Default what is an easy swap for my cb7(92 accordlx) and i did search
im looking for the best gain/ all most direct swap, like how on ef's a dohc is all most direct swap... so im looking for a swap for the accord along those lines. i have searched all i have found is ratings(hp) from what i have found it looks like the f22b will be the closest swap....so can someone let me know if im right or wrong??? thanks for any info
Old Jan 19, 2005 | 07:10 PM
Default Re: what is an easy swap for my cb7(92 accordlx) and i did search (hatchinprogress)
bump
Old Jan 19, 2005 | 09:56 PM
CD7power's Avatar
H22?
Old Jan 19, 2005 | 10:06 PM
327da9's Avatar
The f22b is very similar to the h23, and i believe both engines are about 160hp, and i believe all you need is the ecu to run those engines so it is essentially plug and play.
The h22 would be the best swap in a 92 accord, however little items like the power steering lines and wiring modifications must be done in order to complete the swap. As for the mounts you will have to search although a i believe the stock mounts do work. The h22 swap would offer the largest power gain since the automatic h22's are about 185hp and the manual h22's are 200hp.
I personally would not waste my money on the h22 swap unless your car is a 5spd, or you plan to convert to a 5spd.
Old Jan 20, 2005 | 02:25 AM
The_Todd's Avatar
Farts in the shower
Easiest swap would either be the f22b dohc, h22 or a f22b1 or a direct replacement f22a1/4/6.
Old Jan 20, 2005 | 08:16 AM
Default Re: what is an easy swap for my cb7(92 accordlx) and i did search (VR)
thanks for the feed back guys, i forgot to mention that the car is a 5-speed and from what i have found out: i can use my f22a1 tranny for the f22b is that correct? (i dont want to use a jdm tranny, ive been told that they are beat up in 1st and 2nd gears) also if i get the f22b could i use my stock a/c and power steering??? fyi: this car is a daily driver i know that there are bigger/better engines out there but im just looking for somthin better than stock(to replace my tired *** engine) because my civic is the quick car
Old Jan 20, 2005 | 08:21 AM
SuperSlow's Avatar
Yes.
doughboi904
Mar 5, 2010 05:46 PM
speedyplumbing
10
Feb 22, 2010 06:10 PM
Dav94Lx
Feb 16, 2008 06:56 AM
VTEC R
Dec 5, 2006 06:57 PM
3grider
Apr 25, 2006 05:30 PM
