eg sway bars
I believe stock Si's do NOT come with a rear sway bar. They do come with a front sway bar.
EG Si with RSB's are the ones that have been modified by the previous owner(s). You can get Integra rear LCA's to mount the endlinks to.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z3dtek »</TD></TR><TR><TD CLASS="quote">eg6's came with rear sway bars. u can use them for ur car.</TD></TR></TABLE>
yes, but you will need itr, 88crx, or jdm eg rear shocks.
These are the USDM models with factory sway bars who's LCAs are interchangable.
92-95 Ex 4 door had 13mm rear sway
94-97 Del sol VTEC had 15mm rear sway
94+ Integra LS/GSR had 14mm rear sway
97+ ITR had 22mm sway
Do not use a 22mm sway bar on a civic without subframe reinforcment (comptech, ASR etc..).
ITR LCAs are not compatible with Civic shocks (you need ITR or 88 CRX).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! »</TD></TR><TR><TD CLASS="quote">These are the USDM models with factory sway bars who's LCAs are interchangable.
ITR LCAs are not compatible with Civic shocks (you need ITR or 88 CRX).</TD></TR></TABLE>
good info. the 96-00 EX, 99-00 Si, and CTR sways will fit also, right? i know EK LCA's won't interchange, but will the EK sways fit with the same hardware?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rodrez. »</TD></TR><TR><TD CLASS="quote">My 93 Si came with front and rear factory sways.</TD></TR></TABLE>
Not acording to the honda parts department...
Not acording to the honda parts department...</TD></TR></TABLE>
According to the 2 old rusty sway bars in my garage that I took off, it did.
here ya go....drilled in the center of the arm and I am NOT worried at all about breakage. I tapped the hole 10x1.25 to use stock 14mm bolts in there and then a nut on the back for comfort. I used collars from seat belt to fill the gap, otherwise the end link would bind. Works as good as it did with my GSR LCA's, but I loaned them to my bro
JDMCivic95EG
Suspension & Brakes
18
Jul 7, 2010 09:44 PM
57IAL_Lyle_Civic
Suspension & Brakes
Dec 8, 2007 02:37 PM
spock_rocker
May 23, 2004 06:43 AM
