NEED HELP WITH DISTRIBUTOR PROBLEM
Old Jan 19, 2005 | 02:08 PM
dozer1313's Avatar
Default NEED HELP WITH DISTRIBUTOR PROBLEM
I swapped a SOCH non vtec ZC and the distributor did not clip to my stock civic (civic is a 99) wiring harness .So will my civic distributor work it has a D16Y8 vtec engine.The distributor fit perfect in place ,but have other censor problem before i can try to start the engine.(Problem posted as WILL IT RUN NEED HELP) AND also do you know if the civic head will fit the zc. The ZC is a 1.5 the civic is 1.6.AND if it does fit will i have to run a oil pressure line for the vtec like a LS vtec conversion
Jer99Si
Jun 18, 2004 08:06 AM
ls95hatch
Mar 21, 2003 06:21 PM
