Car not running right
I put my turbo kit on about 2 months ago and it hasnt been working right since then. I just put a missing link on it and my engine check light still comes on and the car runs no better. When i floor it at about 4500 rpms the car starts studering and backfiring until i let off about 3/4 off the gas then it starts to pull a little harder but not much. I have a garret t3/t4 turbo, straight 3 inch exhaust and a 3 inch downpipe, rfl bov, and tial wastegate with a 8psi spring. I have no fuel managment at all and i know i need it but still should it run this bad? Im ordering a vafc controller soon so is that the problem, because I have no fuel managment? And my boost gauge is reading 8psi, thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-d »</TD></TR><TR><TD CLASS="quote"> I put my turbo kit on about 2 months ago and it hasnt been working right since then. I just put a missing link on it and my engine check light still comes on and the car runs no better. When i floor it at about 4500 rpms the car starts studering and backfiring until i let off about 3/4 off the gas then it starts to pull a little harder but not much. I have a garret t3/t4 turbo, straight 3 inch exhaust and a 3 inch downpipe, rfl bov, and tial wastegate with a 8psi spring. I have no fuel managment at all and i know i need it but still should it run this bad? Im ordering a vafc controller soon so is that the problem, because I have no fuel managment? And my boost gauge is reading 8psi, thanks</TD></TR></TABLE>
Stop driving the car like that, its called lack of fuel, what do you think was going to happen? When you boost a car you need some fuel. Look into uberdata with some 450cc DSM injectors. http://www.ecimulti.org/uberdata
It is backfiring and **** because you are incredibly lean, so stop trying to boost the car.
You have all this name brand junk on your car and didn't address the biggest issue of all, I think someone misinformed you or you didn't do some research before you put the kit on? Try looking around the forum for some more answers.
I don't think you can put them in upside down, I think there is a definite way to tell. You can tell by blowing into it. My Missing link would not work with my car above 8lbs, so I think it is about useless anyway. Check valves would be better, but still going to blow it up pretty quickly like that.
could i get some dsm450cc injectors with a resister box and a v-afc to control the fuel? Im going to stop driving it and havent been driving it for about a month but i just want to get it fixed asap. Anyone selling 450cc injectors or a vafc. thanks for your replies
VAFC just isn't the way to go now a days. Check out the uberdata forum, I sent you an email. http://www.ecimulti.org/uberdata
There are many sets of 450s on ebay right now. Check them out.
get a set of used p and h 440 injectors some injector clips and a resistor box and a apexi safc2 i got mine from brian at ar fabrication in va 540 722 dyno they also have hondata and aem
dont i want to get a vafc2 so i can control my v tec? But if anyone is selling injectors or vafc just tell me and i will buy. do u guys think this set up would be good for right now. thanks
a vafc will controll ur fuel too. u need something to controll ur fuel or else, like everyone else said ur gonna blow it up. but yes u can use it too control v-tec also. if thats all u can afford to get than do. i think u will be with it running 8 psi but no more than that. good luck.
use a vafc at your own wish. I know it is simple and what not. But what is so hard about getting uberdata for what, $150, the cost of a vafc2... still blows my mind that it is even an option for a boosted car anymore.
sorry that i dont know anything about uberdata but can you tell me an exact price to buy or have you do all the stuff so that i can run uberdata? Im new on ems but thanks for your help.
I actually do chip ecus, if you need help with that. But read up on the uberdata FAQ. You can email me at uncgolf25@aol.com
Moates's kits were $15 like 2 weeks ago, when did they go up? A basemap is going to run this guys car way better than no fuel management and probably better than a vafc. My basemap runs my car great, until this kid I know finally gets his wideband. ;^)
ya i did ALOT of research but i dont have much money to spend at all so i cant buy everything i want so i have to go the cheap way. Hell if i had alot of money i would just go out and buy a car that already has all the stuff i would want. thanks
well if you had done any research at all you would have known that you won't be able to boost **** without some form of fuel managment so there was no point in even putting the stuff on in the first place. Besides you could get an fmu for probably $75..at least that is a start.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-d »</TD></TR><TR><TD CLASS="quote">ya i did ALOT of research but i dont have much money to spend at all so i cant buy everything i want so i have to go the cheap way. Hell if i had alot of money i would just go out and buy a car that already has all the stuff i would want. thanks</TD></TR></TABLE>
STOP DRIVING THAT CAR! Turbo-D, are you OBD0 or OBD1? Uberdata will not work on OBD0 but Turbo Edit will. E-mail me @ ncervantes@gmail.com if you need some help with turbo edit chipping.
p.s. I also have a FMU with fuel pressure gauge and a connection to your fuel rail. This will at least hold you over until you decide to put a little bit of money into ecu/dyno. hit me up....
Modified by ncervantes at 2:42 PM 1/21/2005
