syncrowave 180 sd and what i need to get started.
Old Jan 19, 2005 | 10:46 AM
ineedhelp's Avatar
Default syncrowave 180 sd and what i need to get started.
im looking to purchase this welder in the near future most likely from here:
http://cgi.ebay.com/ws/eBayISA...&rd=1
it comes with:
-Power source with primary cord
-150 amp TIG Torch with 12 1/2 ft (3.8 m) cord
-12 ft (3.7 m) work cable with clamp and quick-connect
-Electrode holder and quick-connect
-RFCS-14 Foot Control with 20 ft (6 m) cord
-Gas regulator and gas hose
ive taught myself how to weld with flux and mig pretty nicely with the welder at the shop but now i want to advance to tig. ive tried tig welding once at my previous job, but thats with everything hook up and ready to go.
what other equpiments do i need to get started? (other than proper techniques and ways to weld, hopefully that will come with practice and playing around with it)
Modified by ineedhelp at 10:56 PM 1/19/2005
Old Jan 19, 2005 | 12:36 PM
fulldragcrx's Avatar
Default Re: syncrowave 180 sd and what i need to get started. (ineedhelp)
bottle o argon and filler rods. oh and a grinder to grind your tungsten.
Old Jan 19, 2005 | 01:10 PM
B18C1CYA's Avatar
you will need some tungsten , they only give you one stick , and you might want to look into a gas lense
Old Jan 19, 2005 | 01:30 PM
Machine1's Avatar
Default Re: syncrowave 180 sd and what i need to get started. (B18C1CYA)
what are the gas lense for.
Old Jan 19, 2005 | 01:41 PM
98AccordEX's Avatar
Default Re: syncrowave 180 sd and what i need to get started. (Machine1)
you'll also need a plug for the cord. plus some tungstens, filler rods, argon, and metal to weld
Old Jan 19, 2005 | 01:43 PM
B18C1CYA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">what are the gas lense for.</TD></TR></TABLE>
well you use them for better gas coverage over your weld ,
Old Jan 19, 2005 | 01:57 PM
ineedhelp's Avatar
thanks for the input.
what is back purging.
Old Jan 19, 2005 | 03:05 PM
Engloid's Avatar
OG Fabricator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ineedhelp &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the input.
what is back purging.</TD></TR></TABLE>
Check this link for pictures of what it does. It's basically filling the inside of the pipe with argon so that it doesn't get contaminated...as the pics show. Check them out and if you have questions, you may want to ask them in that thread.
https://honda-tech.com/zerothread?id=588002
manifoldmiketyson
Welding / Fabrication
12
Sep 7, 2012 03:15 PM
wade
May 17, 2011 09:02 PM
killerpenguin21
11
Sep 5, 2008 04:02 PM
dem0nk1d
Aug 3, 2008 09:51 AM
