4th gen: Low Fuel Light no longer lit
Old Jan 19, 2005 | 09:36 AM
mrvinyl33's Avatar
New User
Default 4th gen: Low Fuel Light no longer lit
This just starting happening after having 4 new tires installed in Nov. While I know that can affect mileage (roll resistance, new tread, etc..) that sounds coincidental.
I use the trip mileage indicator as I have sometimes needed to add 15.x gallons to get a full tank. Also, noted when full the needle may be higher above F then it used to be. Is that normal?
I was searching and found it could be the fuel sending unit. Is it more common for the 4th gens to have a bad f.s.u. or just a burnt out indicator bulb, or ...? If the f.s.u was bad wouldn't the gauge reading be way off??
Old Jan 19, 2005 | 03:44 PM
matt_in_sd's Avatar
Default Re: 4th gen: Low Fuel Light no longer lit (mrvinyl33)
If the low fuel light doesn't come on when you first turn the ignition on then the bulb is burned out. Cost $5 at dealer. On 6th gens the low fuel light is a whole different circuit then then the guage. I'm not sure on older models.
Old Jan 20, 2005 | 07:03 AM
mrvinyl33's Avatar
New User
Default Re: 4th gen: Low Fuel Light no longer lit (matt_in_sd)
Hmmm, I never remember that light turning on when starting the car even when I know it did work.
Old Jan 20, 2005 | 08:22 AM
SuperSlow's Avatar
Same here. Mine must have been out when I bought it, along with the clock, ODO lights...
uhhkilleez
Apr 10, 2012 05:30 PM
dlbazini
Apr 4, 2009 03:21 PM
tkevin07
Apr 5, 2006 05:24 PM
Unlimitationz
Jun 22, 2005 10:22 PM
GSRaCeRbOI
Sep 3, 2002 05:26 PM
