Timing belt change questions
Old Jan 19, 2005 | 07:42 AM
Toldge's Avatar
Default Timing belt change questions
Will I have to remove the strut/spring assembly and rotor/hub assembly on the drivers side to change the timing belt?
Old Jan 19, 2005 | 07:56 AM
SpeedFreak77's Avatar
Default Re: Timing belt change questions (Toldge)
Rotor hub no, spring and strut will make it a lot easier. If you do a search there is a guy on here that did a whole do-it-yourself with pics. It's a good starting point.
Old Jan 19, 2005 | 12:09 PM
alotawatts's Avatar
Default Re: Timing belt change questions (SpeedFreak77)
Yo SpeedFreak77 ...with an avatar like that your user name should be Jugs !
Old Jan 19, 2005 | 03:27 PM
hondadude's Avatar
STOP You don't need to remove any suspension to do a timing belt on a honda.
Try this link http://www.cybertrails.com/~pu....htmlhttp://www.cybertrails.com/~puf/Honda2.2/997Honda2.2TimeBalNote.html
Jaydeep
Mar 26, 2011 04:25 PM
zeplin
Jan 25, 2009 07:44 AM
timlush
Jan 9, 2007 04:22 PM
grngsr01
Mar 14, 2005 05:19 AM
NyStreet's_4life
Apr 10, 2004 11:01 AM
