97 Accord EX Valve clearance adjustment questions...
Old Jan 19, 2005 | 06:48 AM
vabchaccord's Avatar
Default 97 Accord EX Valve clearance adjustment questions...
Is this a fairly easy procedure to do? I have a copy of the service manual instructions, and have a pretty good mechanical ability, if i follow the procedure, should it be relatively painless? Any tips, hints, suggestions? Thanx in advance.
Old Jan 19, 2005 | 12:16 PM
alotawatts's Avatar
Default Re: 97 Accord EX Valve clearance adjustment questions... (vabchaccord)
Take your time and do not make the mistake someone did in the CIVIC forum of stacking feeler gauges to get the correct gauge !
You might want to invest in a new gasket and plug and mounting bolt seals .
Old Jan 19, 2005 | 03:33 PM
matt_in_sd's Avatar
Its not hard to do, but if the valves aren't making noise dont mess with them.
Old Jan 19, 2005 | 04:51 PM
srfnscubamunkey's Avatar
Default Re: 97 Accord EX Valve clearance adjustment questions... (matt_in_sd)
easy to do but what he said ^^^^^^^^^^^
R1Moon
Sep 27, 2007 04:01 AM
van man
Apr 3, 2007 02:06 PM
rollercosta123
Aug 25, 2006 06:38 PM
vabchaccord
Nov 2, 2004 03:49 AM
AccordSE97
May 24, 2004 10:00 AM
