Suspension & Brakes Theory, alignment, spring rates....
Tokico Blue longevity
Old Jan 19, 2005 | 03:22 AM
Vanilla Sky's Avatar
Default Tokico Blue longevity
I recently purchased a front set of used Tokico Blue struts for my accord. I was told that they have about 7,000 miles on them. They were used with a set of 1.5 inch drop lowering springs for that time. They will be used with stock springs on my car. How long can I expect them to last? I was hoping to get about 50,000 or so more miles out of them with somewhat hard driving. Is this too much to ask? I purchased them to replace my blown OEM struts, not really for performance.
thanks in advance
Derick
[edit]Also, are these struts rebuildable?[/edit]
Old Jan 19, 2005 | 04:21 AM
ki3t's Avatar
This user can set his title.
Default Re: Tokico Blue longevity (Vanilla Sky)
I'm sorry but tociko sucks. As many chances I have it. It all blew.
Old Jan 19, 2005 | 04:44 AM
Default Re: Tokico Blue longevity (ki3t)
the only aftermarket struts for my car made now are tokicos and bilstiens... the only ones in there worth it are the bilstiens, which aren't valved that great for my application...
i have an 88 accord, just so you know the lack of support...
Old Jan 19, 2005 | 09:00 AM
brg2nr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki3t &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry but tociko sucks. As many chances I have it. It all blew. </TD></TR></TABLE>
agreed... I have had many sets and all have blown within 2 years. GO KONI!!!!
Old Jan 19, 2005 | 11:56 AM
J.EM1's Avatar
Team Purple
Default Re: Tokico Blue longevity (brg2nr)
Tokico sucks..go with Koni or kybs
Old Jan 19, 2005 | 12:31 PM
Tad's Avatar
Tad
Default Re: Tokico Blue longevity (SiDriven)
yeah tokico sucks,
but those shocks are rated to handle a 1.5" drop,
so if you're running stock springs you should be ok.
assuming the guy you bought them off wasnt lying about the dropsprings he used.
so basically, what you are using them for, will be just fine,
they are damped SLIGHTLY better than stock shocks.. so it'll be an improvement I think.
but this all depends on whether or not the previous owner ruined them or not.
but you already bought them so **** it.
if you have them, push the piston in/out of the shock,
see if it goes in/out with resistance, or if it just dumps in there easily,
it should resist your attemps and go in/out smoothly.
there should be no oil or anything leaking out also.
Old Jan 19, 2005 | 01:10 PM
well, i was assured that they weren't blown... these are just to hold me over while i fix the rest of the suspension and after i get that done, i'll order some revalved bilstiens with GC coilovers... i figure about 50,000 miles...
Old Jan 19, 2005 | 01:12 PM
Tad's Avatar
Tad
Default Re: (Vanilla Sky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Sky &raquo;</TD></TR><TR><TD CLASS="quote">well, i was assured that they weren't blown... these are just to hold me over while i fix the rest of the suspension and after i get that done, i'll order some revalved bilstiens with GC coilovers... i figure about 50,000 miles... </TD></TR></TABLE>
hahaha, good luck not changing your mind in 50k miles man.
but anyways, if they're not blown, then you'll definetely be fine for years on stock springs.
Old Jan 19, 2005 | 02:06 PM
Default Re: (Tad)
eh? what do you mean by that? there's nothing else available for my car... no konis made any longer, the KYBs for my car are garbage, leaving bilstiens... now if koni would again make struts for an ancient car, i would buy them...
Old Feb 7, 2005 | 06:17 PM
Bob41699's Avatar
i have h&r springs that drop my 97 civic 1.75 front, 1.5 rear and i juss ordered Tokico HP series, how do u guyz think that combo will work out?
Duc_du
Suspension & Brakes
15
Apr 20, 2009 03:49 PM
kodarren
Suspension & Brakes
Apr 16, 2006 09:35 PM
Reelizmpro
Dec 9, 2004 11:56 PM
EGcivicBoy
Jul 17, 2004 10:43 AM
Toda Party
Nov 6, 2002 09:18 AM
