B18b1 in 93 Si-Knock sensor
Old Jan 18, 2005 | 09:50 PM
93CivicSiSOHC's Avatar
Default B18b1 in 93 Si-Knock sensor question
I checked the codes the other day and i came up with #6 (coolent temp sensor) and #8(top dead center sensor). Now my OBD2 distributor is rewired to OBD1. DO i need and OBD1 Distributor to get rid of the Knock sensor code? I think this is one of the reasons my car is runnign bad. I replaced the Coolent temp sensor about 3 months ago..an't figure out why its throwing that code. any ideas?
Modified by 93CivicSiSOHC at 6:33 AM 1/19/2005
Old Jan 19, 2005 | 02:34 AM
ttt
Old Jan 19, 2005 | 06:05 AM
blackeg's Avatar
Default Re: (93CivicSiSOHC)
did you clear the ecu after replacing the coolant sensor? it might just still have the code in its memory. if you are running an obd1 ecu knock sensor wont matter because the b18b obd1 computer doesnt look for it....
Old Jan 19, 2005 | 12:36 PM
Hmmmmm.....
Why would I have a cel #8 which is top dead center sensor?
I will reset ECU and check codes again to make sure.
Old Jan 19, 2005 | 01:03 PM
Slopoke's Avatar
Default Re: B18b1 in 93 Si-Knock sensor question (93CivicSiSOHC)
I'm confused.
You pulling code 6 and 8, neither of which are a knock sensor code.
obd1 ls ecu does not even use a knock sensor, so it wouldnt be pulling a knock sensor code.
Top dead center sensor is located in the distributor.
Old Jan 19, 2005 | 02:40 PM
oh its in the distributor? damn...i guess i have to get a new distributor then?
Old Jan 19, 2005 | 02:46 PM
JDMH22HATCH's Avatar
Default Re: B18b1 in 93 Si-Knock sensor question (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">I'm confused.
Top dead center sensor is located in the distributor.</TD></TR></TABLE>
Exactly what I was about to say. You can open up the distributer and check everything out. Make sure your wiring is correct, etc. If it does have to be replaced, and if you have any other obd1 d, b, h, or f series distributers laying around, you can use those internals and swap them out.
Old Jan 19, 2005 | 06:18 PM
thanks everyone for the reply's i will post up when i get it fixed. I can't wait for it finally to run right now that i know what it is.
elmejor
Sep 6, 2008 07:05 PM
h22hatch88
Feb 27, 2008 06:33 PM
calgone47
Oct 6, 2004 11:46 AM
Grip
Jul 13, 2004 08:43 AM
