How often do you change your plugs?
How often do you change your plugs? And what kind are they?
I know that copper plugs last 10K, give or take a few more thousand in N/A form but since this is the F/I forum and my car is boosted, I was just wondering about the lifespan of copper plugs (specifically NGK-BKR7E).
Thanks!!
Thanks!!
I run ngk r5671A-9 with a 25 thousands gap in my car. I check them regularly to make sure they are still looking okay. Really depends on the weather. In the cold they only last a few weeks, but in sunny southern california they last awhile. Really awesome plugs though, the best ive ever used.
liam
I haven't changed plugs since I've been turbo (like 5,000 miles) and I was running these same plugs for about 20K before that. Regapped them a little while ago but why spend money when you don't have to?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">i change my plugs with every oil change</TD></TR></TABLE>
My car needs a retune, but If I don't change my plugs by 4K I get hard starting and misfiring.
I went 45K (30K turboed) on the factory original plugs, I checked them probably a dozen times, and they always looked great. When I finally got the Hondata, my tuner replaced the factory plugs with the '7' heat range, and I haven't changed them since, maybe 5K miles, I'll check them before I drive the car again in the spring, but don't expect any issues.
I have NGK Iridium heat range 7 plugs and they are rated to last 100,000 miles. Just took mine out the other day to look at them 9,000 miles so far and they look just the same when last took them out for a look at 3,000 miles.
NGK Iridium plugs gets a ....
For the price they cost it'll save you money in the long run and they'll give you better performance...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">Advanced auto just bought this week 12 for 21.00, so less than 1.75 ea.</TD></TR></TABLE>
BKR7E's?
BKR7E's?
The Advance Auto Parts or any of its sub divisions do not stock BKR7Es and must be special ordered.
If there's any online links to where I can buy them in mass quantities, please direct me.
Thanks!!!
Thanks!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">The Advance Auto Parts or any of its sub divisions do not stock BKR7Es and must be special ordered.
Thanks!!!</TD></TR></TABLE>
here ya go Matt...
http://ngk.com/results_cross.a...&y=14
here ya go Matt...
Thanks cuz..
BCPR7ES (stock 3330) for the link you gave me?
I found some BKR7E (6097) http://ngk.com/results_cross.asp?pid=BKR7E
$2.24 each
Thanks!
$2.24 each
Thanks!
NGK bkr7e thats what i run i told o'reilly to stock them so they always have two or so boxes on hand i buy 8 at a time it cost $13 and change them when ever my car starts to cut out up top so it could be 500miles or 5000 miles it always changes.
