srs light flashing while cheking cel codes
Old Jan 18, 2005 | 08:18 PM
MOVE OVER's Avatar
Default srs light flashing while cheking cel codes
thanks for the faq on the codes, they were a big help. when i checked my code, i had a code 41, or oxygen heater sensor. i just bought one, but now i dont know if somthing else is normal or not
should the srs light be on or flash or anything when i check for the code. it is not on any other time, but continues to flash, on and off, same pace all the time as long as i have a jumper wire in and the ignition on...
any help is much appreciated
Old Jan 18, 2005 | 09:05 PM
ForcedEk9's Avatar
Default Re: srs light flashing while cheking cel codes (KGsITR)
so you do have it bridged right? It's just going off at same pace? No pattern?
Old Jan 18, 2005 | 09:10 PM
MOVE OVER's Avatar
Default Re: srs light flashing while cheking cel codes (ForcedEk9)
it is bridged right. going off at same pace. there is no pattern to it. once i undo the bridge and just drive or whatever, the light is never on
stackz
Aug 17, 2008 10:13 AM
bright rider
11
Feb 28, 2007 12:43 PM
discrete
Oct 24, 2005 07:14 PM
JDM-EJ1
Apr 5, 2005 11:55 AM
PM-Performance
Nov 30, 2001 10:53 AM
