Suspension & Brakes Theory, alignment, spring rates....
Sway Bars or adjustible shocks?
Old Jan 18, 2005 | 07:33 PM
racer_X_123's Avatar
Default Sway Bars or adjustible shocks?
Hey, I was wondering what everyone thought about shocks or sway bars, what should be done first, and in what order.
Old Jan 19, 2005 | 01:39 AM
travis's Avatar
Default Re: Sway Bars or adjustible shocks? (racer_X_123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racer_X_123 &raquo;</TD></TR><TR><TD CLASS="quote">Hey, I was wondering what everyone thought about shocks or sway bars, what should be done first, and in what order.
In order:
1) fix anything that is old and/or broken
2) don't drive like a jackass
3) determine what your car and suspension are doing under various conditions
4) repeat step 3 while remembering step 2 until you're sure it's not just the loose screw behind the steering wheel causing the problem
5) armed with the info in 4, read about how springs, dampers, sway bars, etc. contribute to the way the car handles and what (if anything) can be controlled by you or new equipment or both
6) buy only what you need (which might be nothing at all...bravo)
7) repeat step 3 while remembering step 2
8) repeat step 1
Old Jan 19, 2005 | 04:23 AM
.RJ's Avatar
.RJ
Default Re: Sway Bars or adjustible shocks? (travis)
Old Jan 19, 2005 | 09:19 AM
suspendedHatch's Avatar
Default Re: Sway Bars or adjustible shocks? (.RJ)
For street, start with swaybars. If you want stiffer than 18mm rear sway, first you have to upgrade the springs. I put GSR front and rear sways onto my DX Civic. Then I went with coilovers, then I went to a stiffer aftermarket rear sway.
Old Jan 19, 2005 | 09:20 AM
.RJ's Avatar
.RJ
Default Re: Sway Bars or adjustible shocks? (shaundrake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaundrake &raquo;</TD></TR><TR><TD CLASS="quote">For street, start with swaybars. </TD></TR></TABLE>
Swaybars arent going to do anything if he has busted *** shocks.
Old Jan 19, 2005 | 11:23 AM
Mordeki's Avatar
Abusing my rights one day at a time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travis &raquo;</TD></TR><TR><TD CLASS="quote">
In order:
8) repeat step 1</TD></TR></TABLE>
damn.......no ****** around there
sshiny007
10
Nov 13, 2009 03:26 PM
mc
Suspension & Brakes
Nov 18, 2005 05:48 PM
BluntMan
Dec 25, 2002 01:29 PM
osbornsm
14
Jul 23, 2002 12:39 PM
RacerXI
Sep 1, 2001 07:34 AM
