JDM D15B OBD0 Distributor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trustnoone7935 »</TD></TR><TR><TD CLASS="quote">how do you know it's obd-0 what did it come out of.and is it vtec?</TD></TR></TABLE>
The engine is usually OBD-1. He wants to swap the D15b into his car using an obd-0 setup. Since the D16Z6 and the D15B are so close (their heads are identical except for the cam), you can think of it as a Z6 (head wise), just use a PM6 distributor. If you have an Si or Hf, you should already have the distributor you need.
its actually obd1 but Im using my pm6 ecu and si intake mani but my distributor is for d16a6 it wont fit the bolt Im not sure but I think I need a zc distributor just want to make sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racenrockj06 »</TD></TR><TR><TD CLASS="quote">its actually obd1 but Im using my pm6 ecu and si intake mani but my distributor is for d16a6 it wont fit the bolt Im not sure but I think I need a zc distributor just want to make sure</TD></TR></TABLE>
Make it fit... thats what I did on my Z6. If you shave enough metal away on the inside of the arms coming off the distributor, you should get 2 bolts thru to bolt up. I have one on right now and another bolt with washer holding it from the outside of the arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">
Make it fit... thats what I did on my Z6. If you shave enough metal away on the inside of the arms coming off the distributor, you should get 2 bolts thru to bolt up. I have one on right now and another bolt with washer holding it from the outside of the arm.</TD></TR></TABLE>
thats fine if you want to stay obd-0,if your going obd-1 like me you need the z6 or
d15b dizzy and the p28 ecu (p08 w/d15b i think thats it)and a jumper harness to unlock the full potential of your motor,the vafc and pm6 will work but you'll never reach your motors full potential your p28,p08 will engage vtec as well as your air/fuel maps(hints no need for vafc) and someone can burn you a basemap for your bolt-ons
dr_latino999
Aug 18, 2005 06:21 AM
dr_latino999
Jul 25, 2005 06:12 AM
