Suspension & Brakes Theory, alignment, spring rates....
lowering question
Old Jan 18, 2005 | 06:29 PM
Wookie768's Avatar
Default lowering question
im gonna be putting rims on soon
so im gonna drop the car first
only because the suspension needs to replaced , its worn out
so im gonna be putting 15-16 inch rims cant decide yet
and i want it to perform and look better
so how low should the car be lowerd with out looking retared
and when i do replace this stuff
i need lowring springs and shocks
btw im a new to suspension .... shocks is the same as Coilovers right?
Old Jan 19, 2005 | 01:44 AM
travis's Avatar
Default Re: lowering question (Wookie768)
shocks = dampers which are only part of a coilover suspension. Most honda suspensions are coilover in design, but people generally refer to adjustable coilovers as simply "coilovers."
Don't bother asking how low you should go so that it looks good. It only matters what you (and the girlies on your block) think looks good. If you or the girlies can't decide, go with the adjustable variety so that you can change it whenever you want. Find a good height, set your alignment, and forget about it.
Old Jan 19, 2005 | 12:25 PM
Wookie768's Avatar
Default Re: lowering question (travis)
so pretty much just get adjustible coilovers?
Old Jan 19, 2005 | 12:28 PM
Tad's Avatar
Tad
well how much can you spend on suspension??
you could go anywhere from some agx/illuminas and dropsprings(around 4-500dollars)
to koni's and ground controls(great setup around 700)
or some full coilovers (anywhere from 600 to 3000! )
Old Jan 22, 2005 | 12:30 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wookie768 &raquo;</TD></TR><TR><TD CLASS="quote">so pretty much just get adjustible coilovers?</TD></TR></TABLE>
Well, you don't NEED them, but in your case they would allow you to adjust your ride height in both directions until you were happy with the results. This saves you from buying more than one spring length on a non-adjustable setup.
Robot Sonic
Jul 18, 2004 03:45 PM
WesticLe
Jul 19, 2003 12:30 PM
Knight2000
Sep 27, 2002 03:40 PM
92TypeR
Jun 6, 2002 03:26 PM
