Weapon R throttle rotor
Check this out. I have an DC2 LS and I got a weapon R throttle rotor. I was very skepticle about this part. My big worry was throttle getting stuck wide open. But I do have to say that it was worth the five minutes it took to put on, and it wasn't too expensive. (Apparently, Weapon R is coming up in the world.) It greatly increases the firmness of the throttle pedal. (That part I liked.) And obviously the cable is tighter so the throttle is a little more open than what it was at stock. So it does somewhat increase throttle response eventhough I have the stock LS throttle body and stock injectors. If someone is looking for a simple mod that will definately increase <U></U>feel,<U></U> then this is a cool little piece to get. I put it on the same level as a short shifter. There are big debates about whether or not the short shifter helps, but the increase in feeling is great for sure. Just like the throttle rotor.
I know that this sounds like a marketing ploy, but I was unsure as well and I tried it and I'm loving it.
P.S. It's not just for ricers, either
I know that this sounds like a marketing ploy, but I was unsure as well and I tried it and I'm loving it. P.S. It's not just for ricers, either
First off, you don't have a DC2 if your car is an LS.
Second, that thing is a waste of cash, unless you put it on strictly for the feel of a stiffer gas pedal... My friend got one for free so I put it on my car (2 years ago) and tried it out... wow, took that crap off after going around the block once... Do not like the feeling at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuicyJDM »</TD></TR><TR><TD CLASS="quote">Apparently, Weapon R is coming up in the world</TD></TR></TABLE>i think you have been misinformed. WR was once popular, but nowadays is classified in the same category as ractive and APC...
