Just a survey, how much power are you pushing through clutch/axles/diff
Old Jan 18, 2005 | 06:04 PM
maxspeedhonda's Avatar
Default Just a survey, how much power are you pushing through clutch/axles/diff
Hey what's up guys. This thread is more or less just an survey. Ok here is the question...
What is your clutch/axle/diff. setup and with how much whp/ftlbs?
Just trying to make an educated decison...
Old Jan 18, 2005 | 06:16 PM
XXXRacing's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (maxspeedhonda)
Exedy Twin Disk (non-carbon) / Quaife / Pro-Drive Axles - 600-620 at the wheels.
Old Jan 18, 2005 | 06:20 PM
THE BEAST's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (XXXRacing)
Brian, Old car?
Old Jan 18, 2005 | 06:35 PM
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (Bean-Burrito)
keep em coming, don't neglect the torque numbers, that's where it counts
Old Jan 18, 2005 | 06:47 PM
Aggressive Racing's Avatar
Exedy twin disc,quaife dif,DSS level 5's,627hp 495tq.
1.67 60ft 9.86 at 147
https://honda-tech.com/zerothread?id=1097842
Old Jan 18, 2005 | 06:52 PM
SadisticRacing's Avatar
Don't know if your looking for only high power or all kinds but here it goes.
ACT stage 4 clutch, stock axles and diff. 195whp/155tq.
Old Jan 18, 2005 | 07:00 PM
sleeprhatch's Avatar
great thread
Old Jan 18, 2005 | 09:59 PM
b19coupe's Avatar
255 WHP-171 ft-lbs torque. Clutch Net unsprung 4 puck. Stock ITR diff. Stock axles.
Old Jan 19, 2005 | 05:06 AM
ZEX Man's Avatar
RAM centrifugal single disk, DSS stage 5 axles, welded stock diff. (ghetto value)
425 wtq. / 580 whp
2250 lbs
Old Jan 19, 2005 | 06:15 AM
Zubaltec's Avatar
Tilton twin disk Ceramic, Pro Drive spool, Pro Drive Stage 1 axles. 736 HP & ?TQ
Old Jan 19, 2005 | 06:19 AM
Brent L's Avatar
900 and 620 tq mark williams axles and spool
comp clutch twin disc
Old Jan 19, 2005 | 01:07 PM
XXXRacing's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (Zubaltec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zubaltec &raquo;</TD></TR><TR><TD CLASS="quote">Tilton twin disk Ceramic, Pro Drive spool, Pro Drive Stage 1 axles. 736 HP & ?TQ </TD></TR></TABLE>
showoff!
Old Jan 19, 2005 | 02:35 PM
nsxmatt's Avatar
250whp, stock oem Honda Type-R clutch, stock diff, stock axles.
1.60 60ft on Slicks, 11.8's 1/4.
Old Jan 19, 2005 | 05:23 PM
clarkBAR's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (nsxmatt)
Clutch Specialties 6 puck unsprung, Quaife & Stock Axles......525hp...375tq
Old Jan 20, 2005 | 04:06 AM
DontBlink's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (clarkBAR)
ACT XTSS
stock axles
Type R tranny with stock diff
385hp
261tq
Old Jan 20, 2005 | 04:15 AM
VisualAutoMotoring's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (DontBlink)
ACT Heavy Duty/Street disc ACT Prolite Flywheel
Gator Stage 3
stock diff
300whp/201tq....&lt;-----nothing compared to you big guys...well again this is just a toy for me
Old Jan 20, 2005 | 04:19 AM
Quik Chris's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (Hybrid-Performance.com)
the old car: Tilton carbon/carbon:946whp 720ft/lb prodrive diff and axles
Modified by Quik Chris at 10:56 PM 1/31/2005
Old Jan 20, 2005 | 05:16 AM
Zubaltec's Avatar
I knew I should have let Darin or James post.
John
Old Jan 20, 2005 | 09:05 AM
seen4ever's Avatar
355whp, 244wlbs ACT 6 puck with Heavy disc, stock GSR diff, pepboys axles
1.78 60fts, 11.75 1/4
Old Jan 20, 2005 | 01:18 PM
sir boostalot's Avatar
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (seen4ever)
anybody use a centerforce clutch?
Old Jan 20, 2005 | 06:04 PM
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (sir boostalot)
keep em coming...
Old Jan 20, 2005 | 09:21 PM
HYBRID_H@TCH's Avatar
536 whp 396 wht. action 2MD. obx lsd. stock axles.
Old Jan 21, 2005 | 12:11 AM
Adi Radoncic's Avatar
On Fire!
Default Re: Just a survey, how much power are you pushing through clutch/axles/diff (99Hybrid_Hatch)
454whp 301tq act hd 6 puck, quaife lsd, autozone axles, consistant 1.7's.
Old Jan 21, 2005 | 10:41 AM
2.2SICKLUDE's Avatar
ACT HDXT Clutch, stock axles, with Quaife
Old Jan 21, 2005 | 01:01 PM
b00stedbyFastrax's Avatar
OS Giken Twin Disc, DSS Stage V, Quaife. ~600whp.
