knocking sounds w/ Sportlines
Old Jan 18, 2005 | 05:59 PM
aj7v's Avatar
Default knocking sounds w/ Sportlines
I posted this earlier today, but in the wrong section. Im posting it here in hope that more EP3'ers will see since that's the car I have. I intalled my eibach sportlines and spc camber the other day and now I have a problem with a knocking sound coming from the rear. it happens when there are dips or small bumps in the road. I tested it out by jumping in the trunk and noticed it only makes the sound when the springs come back up. Any thing I should look for to fix?..
Old Jan 18, 2005 | 06:15 PM
Jaypee's Avatar
Default Re: knocking sounds w/ Sportlines (aj7v)
I'm not too sure about the rear, but when I installed Tein Basic coilover I had spring popping noise from the front of the car. Turns out, I had to remove a plastic ring from the OEM shock and put it with the Teins. Might want to check that out.
Old Jan 18, 2005 | 07:13 PM
S-fiend's Avatar
Also the springs might not be properly postitioned in the strut. This occured after I installed sportlines on my friends talon. Take them off and try to fit them better.
Old Jan 18, 2005 | 07:47 PM
aj7v's Avatar
Default Re: knocking sounds w/ Sportlines (S-fiend)
Thanx, I'll look into this.
Old Jan 19, 2005 | 04:40 AM
kung fu grip's Avatar
this is called indexing...aligning the springs uniformly in their seats.
i gey a knocking on hard left turns, but i know it is the stock exhaust bumping the chasis.
Old Jan 20, 2005 | 10:43 AM
kseriesDC5's Avatar
Default Re: (kung fu grip)
is the top of the strut lose? after you lower ur car from the stands, theres more strut to thread on
Old Jan 20, 2005 | 01:28 PM
aj7v's Avatar
Default Re: (kseriesDC5)
hmm that could be it, loose struts. sounds stupid but I dont have a torque wrench so when i tightend the strut back up i just put the nut back in the same spot. hopefully this helps
thanx
03redEM2
Honda Civic (2001 - 2005)
25
Feb 9, 2009 07:05 PM
Nism05
Jan 3, 2007 11:41 PM
lenny_vp
Suspension & Brakes
Jan 18, 2006 04:12 PM
aj7v
Jan 18, 2005 01:32 PM
deviant1
Dec 3, 2003 05:41 PM
