need help with part for new swap...???
Old Jan 18, 2005 | 05:18 PM
lilfresh's Avatar
Default need help with part for new swap...???
hi. could neone give me a parts list of wat i need to swap a b18 into my 97 civic....??? thank you
Old Jan 18, 2005 | 07:35 PM
BatuKing's Avatar
Default Re: need help with part for new swap...??? (lilfresh)
engine, tranny, wiring, axles, shift linkage, engine mounts, ect ect search
Old Jan 18, 2005 | 08:04 PM
93gsrcoupe's Avatar
Default Re: need help with part for new swap...??? (BatuKing)
Don't forget the ecu and may want to consider new clutch, timing belt, and water pump (just to be safe). And do as much research as you can.
Old Jan 19, 2005 | 10:58 AM
lilfresh's Avatar
Default Re: need help with part for new swap...??? (93gsrcoupe)
ok i have those but i needed to know wen i swap it in my car which type of motor mount n which type of harness do i need???
Old Jan 19, 2005 | 04:52 PM
lilfresh's Avatar
i know some1 in here have done a b series into a 96-00 civic befor...n i just need some hints on wat extra parts do i need to get to put it in...cuz i dont want to take my car apart n den missing parts n have to run around for it..so plzz give me some hints.
Old Jan 19, 2005 | 05:00 PM
ralphie14's Avatar
did you motor not come with mounts or an engine harness?
Old Jan 19, 2005 | 06:01 PM
lilfresh's Avatar
Default Re: need help with part for new swap...??? (ralphie14)
it come with wire harness but not motor mount...but i heard tat i cant use the ls wire harness is tat rite? and cant use the mount from the ls nether?
luisdabsdaily
Honda Ruckus and Scooters
Dec 2, 2013 01:59 AM
K-ITR
K Series
17
Mar 26, 2011 10:14 AM
preetyboi06
Jul 17, 2009 09:57 AM
BishopXIII
Dec 20, 2005 06:10 PM
3.point.2
Jul 1, 2004 06:01 PM
