cat bolt length (spring side)
Old Jan 18, 2005 | 05:12 PM
BlackCRX's Avatar
Default cat bolt length (spring side)
the bolts on my cat with the spring is rounded, im gonna cut the bolt in half
but before i do that i want to know how long the bolt is so i can replace it
does anyone know the length ?? also i was at the local hardware store and they have grade5 and grade8 bolts
which grade is good for the cat or does it not matter ??
thanx in advance
Old Jan 18, 2005 | 05:43 PM
Mr_CRX's Avatar
Default Re: cat bolt length (BlackCRX)
I just bought some cheap bolts, nuts and washers from Home depot. Just reuse the spring from the spring bolts.
I got ones that were a bit longer than I thought (just to be safe) and threaded completely so I didnt really even have to measure. They're probably like 3.5" long. Working fine since last summer.
Old Jan 18, 2005 | 06:03 PM
BlackCRX's Avatar
the only problem is the bolts at our hardware store dont have the fully threated ones
they only have the 1/4 thread style ones
my geusses were around 3.5-4inches in legth
but i was hoping for some confirmation, thanx for the info man
Old Jan 18, 2005 | 09:01 PM
BlackCRX's Avatar
confirmation from anyone ??
Old Jan 18, 2005 | 10:02 PM
trustnoone7935's Avatar
Default Re: (BlackCRX)
cat what cat run straight pipe
Old Jan 19, 2005 | 07:05 AM
BlackCRX's Avatar
well yes i am using a test pipe but i figure "cat bolt" is more understandable compared to "test pipe bolt"
Old Jan 19, 2005 | 08:21 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The threaded portion of the bolt is 8mm
so that or a 5/16" would probably work.
Overall length including the head is 70mm.
Here is a pic for reference:
Old Jan 19, 2005 | 10:06 AM
Mag00n's Avatar
Default Re: (88DXCRX)
Be carefull when you cut the bolt! My friend almost had his eye taken out cutting the bolts on my del sol. THe bolt just missed his head and left a dent in my frame!!1
Old Jan 19, 2005 | 12:06 PM
BlackCRX's Avatar
thanx guys you rock
honda-tech ownzj00
svw
Sep 25, 2003 09:33 PM
TAG
19
Jul 6, 2003 08:19 PM
AllMotorITR
Jul 11, 2002 08:33 PM
