Poll: To "cat" or not to "cat"
Old Jan 18, 2005 | 03:50 PM
JuanK20's Avatar
Default Poll: To "cat" or not to "cat"
I am thinking of removing my Catalytic Converter. I know it makes the car louder which is not what i am looking for. but what other pro's and cons are there? I need some opinions. Does it make more power? Will i even feel a difference? INFORM ME PLease. thanks
FYI: i drive a gsr
Old Jan 18, 2005 | 08:38 PM
sporkcrx's Avatar
Default Re: Poll: To "cat" or not to "cat" (.JDM KiD.)
You n/a or turbo? If n/a, I'd leave it on. If turbo, you can if you want to.
Old Jan 19, 2005 | 07:42 AM
1BadCvC's Avatar
Default Re: Poll: To "cat" or not to "cat" (sporkcrx)
Never had one on any of my cars and probably never will. Only pro i see is that it protects our ozone and whatnot...other than that its just restricting my precious exhaust flow.
Old Jan 19, 2005 | 10:09 AM
BigHeadKid's Avatar
i dont run a cat in mine because it is one more restriction to worry about. if u go this route, i would make or find a dummy cat that looks like you actually have one. it is a monster fine in most places for not having one.
Old Jan 19, 2005 | 11:43 AM
Perfectionist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigHeadKid &raquo;</TD></TR><TR><TD CLASS="quote">. it is a monster fine in most places for not having one. </TD></TR></TABLE>
Actually, it's a federal thing, meaning nation wide. I believe it's about a $2500 fine.
Do what you want, but remember your kids, or those you might want to have.
Old Jan 19, 2005 | 06:09 PM
JuanK20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">You n/a or turbo? If n/a, I'd leave it on. If turbo, you can if you want to.</TD></TR></TABLE>
No.. Im not turbo..
Thanks for everyones input.. Bump, bump, bump
Old Jan 20, 2005 | 05:56 AM
BigHeadKid's Avatar
Default Re: Poll: To "cat" or not to "cat" (Perfectionist)
that is very true. i have a test pipe that looks like a cat.
Old Jan 20, 2005 | 06:25 AM
sonicrex's Avatar
Default Re: Poll: To "cat" or not to "cat" (BigHeadKid)
Not sure what emissions are like in NY. Hey, it's a personal thing. I've always kept mine on my car. Again, as stated above, there are fines for that, blah, blah, blah. So do what you want.
Old Jan 20, 2005 | 06:46 AM
BigHeadKid's Avatar
Default Re: Poll: To "cat" or not to "cat" (sonicrex)
that is true. i think it really does boil down to personal prefernce.
Old Jan 20, 2005 | 06:49 AM
v4lu3s's Avatar
RTFM
a cat does not restrict htat much at all, especially around stock power levels.
it makes quite a diff for sound, and also keeps your rear bumper clean.
plus clean air isnt infinitely available.
Old Jan 20, 2005 | 08:44 AM
BigHeadKid's Avatar
Default Re: (v4lu3s)
bump
Old Jan 20, 2005 | 10:54 AM
JuanK20's Avatar
Default Re: (BigHeadKid)
thanks for everyones advice.. i think imma take it off for like a week or so to see if i like it. if i dont feel any difference then imma put it back on.. one thing is for sure, if it makes too much noise without it, im definatly slapping it back on.
Old Jan 20, 2005 | 10:56 AM
97L-esVeeTeg's Avatar
Default Re: (.JDM KiD.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .JDM KiD. &raquo;</TD></TR><TR><TD CLASS="quote">thanks for everyones advice.. i think imma take it off for like a week or so to see if i like it. if i dont feel any difference then imma put it back on.. one thing is for sure, if it makes too much noise without it, im definatly slapping it back on.</TD></TR></TABLE>
keep in mind that if you just take off your cat and run a test pipe, chances are you're gonna be running a bit lean, so you might want to retune
Old Jan 20, 2005 | 11:55 AM
sporkcrx's Avatar
Default Re: (97L-esVeeTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97L-esVeeTeg &raquo;</TD></TR><TR><TD CLASS="quote">
keep in mind that if you just take off your cat and run a test pipe, chances are you're gonna be running a bit lean, so you might want to retune </TD></TR></TABLE>
It'll be fine without a retune.
Old Jan 20, 2005 | 04:34 PM
BigHeadKid's Avatar
thats a good plan. this way you can do real world testing of both
Old Jan 20, 2005 | 09:19 PM
pearl's Avatar
stinky stinky stinky, keep the cat.
Old Jan 24, 2005 | 03:49 PM
suspendedHatch's Avatar
Default Re: (japearl)
Head down to Tijuana and do some hiking.
Makes your car smell and sound like a giant weed wacker. What sounds like a weed wacker, and what smells like a weed wacker, IS a weed wacker.
A high flow cat causes less restriction in the exhaust as a mandrel bend.
SCC
Suck, Squish, Bang, Blow: Part 2
Improving Suck and Blow or the Old In and Out
By Mike Kojima
"Whatever you do, do not remove or gut out the catalytic converter on your street car. The monolithic, straight through design of modern 3-way catalytic converters is usually quite free flowing on most modern sport compact cars, producing at the most, only a pound or two of extra backpressure. A gutted cat can actually hurt power as the empty box can cause flow stagnation, which effectively shortens the length of the moving gas column in the exhaust pipe. The empty box can also reduce important flow velocity. This can be felt as a loss in bottom end power.
Because of these factors, some of our project cars have actually gained power with the addition of a cat. As the number of vehicles on our highways grows every year, we must all do our part to manage pollution. If every last bit of power must be extracted, as in real, off-the-street sanctioned racing, then the cat can be removed and replaced with a length of pipe, not simply gutted. "
Old Jan 28, 2005 | 11:43 AM
HONDA_TYPE_R's Avatar
Default Re: Poll: To "cat" or not to "cat" (slow poke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow poke &raquo;</TD></TR><TR><TD CLASS="quote">If you are all motor... Keep the cat and save the environment
The gains are VERY insignificant when under 200HP all motor.
Couldn't agree more myself. It also makes your exhaust a little raspier. I personally can not stand that sound. Look around for dynos on JUST an aftermarket catalytic converter or a gutted cat, and you will see that gains are so minimal it's not really worth it, unless you get a 2.5" collector header...then it may be a good idea to at least get a bigger cat.
Old Jan 28, 2005 | 02:18 PM
Jamez's Avatar
There are no gains to be had and your car will sound like crap so just keep it on.
Old Jan 28, 2005 | 09:23 PM
bugster's Avatar
get a hi flow cat and have the best sound, air and power
Old Jan 29, 2005 | 12:27 AM
rice killer's Avatar
Default Re: Poll: To "cat" or not to "cat" (bugster)
god people u really need this extra 1hp...no cat makes your car smoke pretty bad too....and it smells like ******* ****...i know because i ran open headers for awhile...(dont do it) plus u need the back pressure
Old Jan 30, 2005 | 07:51 PM
trustnoone7935's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bugster &raquo;</TD></TR><TR><TD CLASS="quote">get a hi flow cat and have the best sound, air and power</TD></TR></TABLE>
94xGSRxINTEGRA
Jun 11, 2007 09:07 AM
JDM00SI
Oct 15, 2005 09:14 PM
shermanyang
Apr 7, 2003 11:13 AM
