jdm h22a engine service manual.
Old Jan 18, 2005 | 03:12 PM
Eightfuns's Avatar
Default jdm h22a engine service manual.
hey, alot of you probably have built up your jdm h22a's, what i need to know is where you got the information on all the spec's. I have a service manual for my 97 prelude but i dont know if the spec's are the same, I just wanna make sure that when i am building the new engine i follow everything right.
Old Jan 18, 2005 | 03:22 PM
prelittlelude's Avatar
Default Re: jdm h22a engine service manual. (Eightfuns)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eightfuns &raquo;</TD></TR><TR><TD CLASS="quote">hey, alot of you probably have built up your jdm h22a's, what i need to know is where you got the information on all the spec's. I have a service manual for my 97 prelude but i dont know if the spec's are the same, I just wanna make sure that when i am building the new engine i follow everything right.</TD></TR></TABLE>
the h22a is basically an identical engine to the h22a1 with very small differences , diferent piston, internal coil int he dizzy, backwards fuel rail,
if you get a manual for the 4th gen prelude that had a h22a1 you should be all set,
Old Jan 18, 2005 | 03:25 PM
Eightfuns's Avatar
Default Re: jdm h22a engine service manual. (prelittlelude)
right on thanks alot, so just to make sure (Im new to this but it will be fun) the h22a1 has all the same clearances and all that other stuff.
oldskoolchris
16
May 30, 2019 11:34 PM
djnikko
Sep 28, 2004 12:57 AM
jakeludesi
Sep 6, 2004 09:37 AM
HyperFlow
Jun 7, 2003 12:34 PM
mattEX-R
Dec 3, 2001 11:08 PM
