1st gen b16 intake manifold in 97 ex, what to change/plug?
Old Jan 18, 2005 | 01:43 PM
willyboyK20's Avatar
Default 1st gen b16 intake manifold in 97 ex, what to change/plug?
I know with the first gen b16 intake mani there are lots of vacumn lines going everywhere and i won't need them since it is going into an obd-2 car.
I want to know what do i need to plug up or change so i don't have a lopey idle.
I believe i will need to change to a newer T/B due to the map sensor and use iacv from my Y8, but is there anything else.
TIA
Old Jan 19, 2005 | 02:35 PM
Default Re: 1st gen b16 intake manifold in 97 ex, what to change/plug? (willyboyD16)
bump
btw this will be a full 1st gen swap going into a 97 ex, not just the intake manifold
Old Jan 19, 2005 | 02:52 PM
civictildeath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyD16 &raquo;</TD></TR><TR><TD CLASS="quote">btw this will be a full 1st gen swap going into a 97 ex, not just the intake manifold</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by willyboyD16 &raquo;</TD></TR><TR><TD CLASS="quote">i won't need them since it is going into an obd-2 car.</TD></TR></TABLE>
well if it is a full 1st gen swap then it has to be converted to the obd version of that engine
Old Jan 20, 2005 | 10:53 AM
Default Re: 1st gen b16 intake manifold in 97 ex, what to change/plug? (civictildeath)
i already know that it has to be converted but what i wanted to know is what vacumn lines will i not need since the engine is going to be obd-2.
I think i won't need the fast idle valve but i am not sure.
Old Jan 20, 2005 | 11:16 AM
Luserkid's Avatar
If you dont need the vacuum line then just cap it and your good to go.
FIGARILA
Aug 16, 2005 05:14 PM
fatalman
Jul 19, 2005 09:07 PM
bearboy80
Jan 17, 2004 06:57 PM
