can i put 92 accord rear suspesion on a 97 accord
10 minutes between posts?!?!?!
what is "rear suspension"? do you mean rear springs? rear shocks? both shocks and springs? or something else?
if just springs and shocks, you can put them there... but why put old components in a newer car?
well i want to put the hole drum *** andtrailing arm car was in accident and i have this parts extra i dont want to put the strut in just drum assembly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagged93accord »</TD></TR><TR><TD CLASS="quote">Should. 90-97 were the same suspension. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by st_lunatic »</TD></TR><TR><TD CLASS="quote">it should or it does
how about the front </TD></TR></TABLE>
90-97 rear suspension is nearly identical if not exact, it will fit (depending on what you're trying to add on). I am not 100% sure about the front.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uncle_el »</TD></TR><TR><TD CLASS="quote">what is "rear suspension"? do you mean rear springs? rear shocks? both shocks and springs? or something else?
if just springs and shocks, you can put them there... but why put old components in a newer car?</TD></TR></TABLE>
Agreed 100%...we need more info homefry.
To the best of my knowledge it will fit but that is something that should really be researched a bit more before you assume that it will work. Try looking at http://www.hondaautomotiveparts.com and see if the part numbers for the two different years match up.
loup05
Oct 28, 2006 06:56 PM
crexer
Jul 6, 2003 10:03 PM
