Skunk2 versus Edelbrock versus Stock Intake Manifold
Old Jan 18, 2005 | 12:47 PM
Justin Jones's Avatar
Default Skunk2 versus Edelbrock versus Stock Intake Manifold
I'm considering getting a Skunk2 or Edelbrock intake manifold for my turbo D16Z6, but like everyone, I'm on a budget and wondering if I should just swap to a Y8 manifold or something. Is it worth the money to get a Skunk2 or Edelbrock?
The Skunk2 looks like a good piece but looks a lot like a stock Honda manifold while the Edelbrock looks like a really nice piece, much more different from a stock manifold.
here's some pictures to help out, i hope the links work:
Edelbrock
skunk2
I really appreciate any help. thanks in advance.
Old Jan 18, 2005 | 12:55 PM
RyanEJ8's Avatar
Default Re: Skunk2 versus Edelbrock versus Stock Intake Manifold (the kid 86)
If you're on a budget the stock Y8 is probably the best option. If you can afford it go for the Edelbrock.
Old Jan 18, 2005 | 01:00 PM
TeStUdO's Avatar
Default Re: Skunk2 versus Edelbrock versus Stock Intake Manifold (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">If you're on a budget the stock Y8 is probably the best option. If you can afford it go for the Edelbrock.</TD></TR></TABLE>
Yeah if you are running a low boost setup the Edelbrock wouldnt help you that much. Might as well stick with the Y8, and spend your money on a clutch or something.
Old Jan 18, 2005 | 01:26 PM
RyanEJ8's Avatar
I plan on using the stock Y8 manifold and throttle body for my setup with a goal of 300whp+.
Old Jan 18, 2005 | 01:40 PM
SOHC_MShue's Avatar
its been dyno proven that the d16z6 mani makes more power than the y8 which is suppost to be better. I would stick with your stock mani.
Old Jan 18, 2005 | 01:43 PM
RyanEJ8's Avatar
Default Re: Skunk2 versus Edelbrock versus Stock Intake Manifold (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">its been dyno proven that the d16z6 mani makes more power than the y8 which is suppost to be better. I would stick with your stock mani. </TD></TR></TABLE>
I'd like to see that dyno, because I have seen dynos that prove the Y8 to be the better manifold.
Old Jan 18, 2005 | 05:03 PM
SOHC_MShue's Avatar
well it was an all motor dyno. I think its on sohchonda.com, but i'm not sure. I know i've seen it before though.
do you have any boosted dynos of the comparison? I'd like to see them because it would make me feal better about my y8 mani
Old Jan 18, 2005 | 05:55 PM
turbodohcsi's Avatar
well ill be one of the only ones to say this, but on mine (b16a2) i prefer the the skunk 2 "im not only the owner, but im a user"............. so anyways, i have enough turbo lag without stepping up to a larger intake manifold. i have enough traction issues as is in the higher rpms, so i wanted more midrange power to higher range power. so i actually like my skunk2.
btw, my friend had a skunk2 and swapped to a jg (13-15 lbs of boost) and he said he didnt notice any difference
Old Jan 18, 2005 | 07:02 PM
.::Lee::.'s Avatar
Default Re: Skunk2 versus Edelbrock versus Stock Intake Manifold (turbodohcsi)
y8&gt;z6
http://www.theoldone.com/forum...ntake
Larry's the man.
Old Jan 18, 2005 | 08:48 PM
Tad's Avatar
Tad
folks at d-series.org prefer the z6 IM over the y8,
i'll take their word for it.
thats for allmotor though.. duno maybe the y8 is good for boost or somethin.
the edelbrock would be nice over any of them imo. Hey its even got that nifty angle TB inlet
Old Jan 18, 2005 | 11:54 PM
W O T's Avatar
Default Re: (Tad)
Venom old school square style &gt; ****************************
Manifold ******* rocks
Had to drill n tap my own IACV but other than that, mani is the ****
Old Jan 19, 2005 | 12:20 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi &raquo;</TD></TR><TR><TD CLASS="quote">
btw, my friend had a skunk2 and swapped to a jg (13-15 lbs of boost) and he said he didnt notice any difference</TD></TR></TABLE>
And im sure your friend didnt take it to the dyno to see if there was a difference either. The JG rapes the skunk2 up top, that is what makes it great for our high revving honda's. If I had the money I would save for the new full race or the AIR carbon Fiber (which basically has no heat soak at all).
Old Jan 19, 2005 | 08:28 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">well it was an all motor dyno. I think its on sohchonda.com, but i'm not sure. I know i've seen it before though.
do you have any boosted dynos of the comparison? I'd like to see them because it would make me feal better about my y8 mani </TD></TR></TABLE>
I think I know the dyno you are talking about, I'll see if I can find it. I can tell you that you can feel better about your Y8 mani though. It has more plenum volume and more overall volume than the Z6 manifold. Runner length is nearly identical.
Old Jan 19, 2005 | 09:48 AM
SOHC_MShue's Avatar
yea i just found that post on sohchonda where they measured the plenums and runners of each. Good stuff
Old Jan 19, 2005 | 09:58 AM
fast94ex's Avatar
Everyone i know that had the edelbrock switched to skunk2 and picked up hp and tq with less lag as well.
Old Jan 19, 2005 | 10:23 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">yea i just found that post on sohchonda where they measured the plenums and runners of each. Good stuff </TD></TR></TABLE>
Do you have the link to that thread. I think there's a link in it to the dyno we were talking about. I want to take a look at it again.
Old Jan 19, 2005 | 10:44 AM
SOHC_MShue's Avatar
here you go
IM comparison
Old Jan 19, 2005 | 10:55 AM
yellowturbo's Avatar
If you can wait a month or so I will do a post about the Edelbrock IM vs the Y8 IM vs Z6 IM. I will do a bunch of test on my flowbench...
I will also test each IM on a stock head vs a Fastech ported head.
Result to come soon.
Old Jan 19, 2005 | 11:08 AM
sohcT's Avatar
Default Re: (yellowturbo)
i just purchased an edelbrock im. probably won't dyno until the spring though.
Old Jan 19, 2005 | 11:29 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo &raquo;</TD></TR><TR><TD CLASS="quote">If you can wait a month or so I will do a post about the Edelbrock IM vs the Y8 IM vs Z6 IM. I will do a bunch of test on my flowbench...
Result to come soon.</TD></TR></TABLE>
can't wait!
Old Jan 19, 2005 | 11:35 AM
Default Re: (SOHC_MShue)
can't wait!</TD></TR></TABLE>
too bad I dont have a Skunk 2 to test it.....
Old Jan 19, 2005 | 12:10 PM
norcalcrx's Avatar
You are going to find that the z6 manifold flows more cfm then the y8. We tested that a while back on a superflow.
Old Jan 19, 2005 | 06:31 PM
Default Re: (norcalcrx)
"And im sure your friend didn't take it to the dyno to see if there was a difference either. The JG rapes the skunk2 up top, that is what makes it great for our high revving honda's. If I had the money I would save for the new full race or the AIR carbon Fiber (which basically has no heat soak at all)."
i think we all know if you drive your car everyday, and pay as much attention to how it drives, you can feel when there has been a decent increase in power. now you wont see the numbers just by feeling if there is power there or not, but you'll know if it made your car faster....... not to mention he had the greddy kit, so that probably made a difference, over having a larger turbo.
Old Jan 19, 2005 | 07:14 PM
nonvtecD's Avatar
ITB's are better ;^)
Old Jan 20, 2005 | 06:22 AM
Boosted96EK's Avatar
I have the edelbrock IM on my Y7 not boosted yet... I did notice a change... Down low its weaker, but up top especially in 3rd gear it pulls harder...
Also for the edelbrock owners... I recieved a throtle cable bracket with mine... but I think they sent me the wrong one so I custom fabbed one... does anyone know if the Y8 bracket will work? I have to replace my throttle cable since the Y7 is too long so if the Y8 bracket works, i'll buy it while im at it..
