front bumper removal
Old Jan 18, 2005 | 11:56 AM
LillDragun's Avatar
Default front bumper removal
am i the only person that is so retarded i can't remove the front bumper? i can't seem to budge the 9 screws that hold the top of the bumper to the chassi. can some help me out here? i'm so stuck! i sprayed lube on it but none of the screws will budge. they feel like they are welded in!!! am i doing something wrong here?
Old Jan 18, 2005 | 12:29 PM
l2Y4N's Avatar
Default Re: front bumper removal (LillDragun)
they shouldn't be that hard unless someone previously added thread locker or something. if it comes down to it, drill them out and get some new ones at the dealer, shouldn't be too expensive.
Old Jan 18, 2005 | 12:49 PM
95TEG's Avatar
Default Re: front bumper removal (integraTracer)
Here u go.
http://www.team-integra.net/se...ID=68
Old Jan 18, 2005 | 02:40 PM
Mordeki's Avatar
Abusing my rights one day at a time.
Default Re: front bumper removal (95TEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95TEG &raquo;</TD></TR><TR><TD CLASS="quote">Here u go.
http://www.team-integra.net/se...ID=68</TD></TR></TABLE>
awesome article
Old Jan 18, 2005 | 03:30 PM
DAguyLS's Avatar
drill dem bitches out and get new ones if all else fails
Old Jan 18, 2005 | 03:53 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (slamdLScivic)
Did you Just try getting them out with a screwdriver, or did you actually try a ratchet with a phillips attachment?
Old Jan 18, 2005 | 04:51 PM
LillDragun's Avatar
Default Re: (FlatBlackTeg)
i just used a screw driver. does the rachet work better?
Old Jan 18, 2005 | 05:16 PM
calxtreme's Avatar
is your screw driver slipping? Are you using some cheapy one? cuz those don't fit well and will cause slipping.
Old Jan 18, 2005 | 05:24 PM
rgaray's Avatar
Use the biggest biggest head thats not too pointy.
Old Jan 18, 2005 | 08:16 PM
LillDragun's Avatar
Default Re: (rgaray)
i'll try that when there's light and when it isn't 40 degs out there. thanx
Old Jan 18, 2005 | 08:24 PM
eluam's Avatar
Default Re: (LillDragun)
Do not strip them bitches. I stripped four of mine trying to replace my headlights 2 months ago. Still haven't gotten them off yet. I've been too busy to worry about it. I've got 4 screws holding on my bumper right now. I didn't use the proper tools and I got what I deserved. I'm probably gonna end up drilling them out, but a mechanic at work is gonna look at them one of these days and see if he has an alternative.
Old Jan 18, 2005 | 10:13 PM
91TegLS's Avatar
Default Re: (geeZus)
Don't drill them out. Just get the proper tool for the job: AN IMPACT DRIVER. Your local auto parts store should have them for around $20, or you can go all out and get the Craftsman one for an extra $5. One of the best hand tools I've ever purchased.
If you aren't sure what one is:
http://www.sears.com/sr/javasr...41000
Old Jan 18, 2005 | 10:33 PM
DAguyLS's Avatar
pretty sure that drillin em out and just going to acura or even a junkyard at that would be the cheapest route.
but the impact driver would be a good buy
Old Jan 19, 2005 | 12:28 AM
SwedBoy2999's Avatar
Default Re: (91TegLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">Don't drill them out. Just get the proper tool for the job: AN IMPACT DRIVER. Your local auto parts store should have them for around $20, or you can go all out and get the Craftsman one for an extra $5. One of the best hand tools I've ever purchased.
http://www.sears.com/sr/javasr...41000</TD></TR></TABLE>
Listen to this guy
Also if you ever decide to change your rotors it will be a big help.
Old Jan 21, 2005 | 03:40 AM
91TegLS's Avatar
Default Re: (SwedBoy2999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwedBoy2999 &raquo;</TD></TR><TR><TD CLASS="quote">Listen to this guy
Also if you ever decide to change your rotors it will be a big help.</TD></TR></TABLE>
Heh, that's what I bought it for. Those little rotor screws are near impossible to remove without it.
Old Jan 21, 2005 | 10:52 AM
LillDragun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91TegLS &raquo;</TD></TR><TR><TD CLASS="quote">Heh, that's what I bought it for. Those little rotor screws are near impossible to remove without it.</TD></TR></TABLE>
yeah i already changed my rotors out with out them.....i just drilled those lill ******* out after i stripped them. i got the cobalt blanks and tossed the oems. i just bought the impact driver. we'll see how this works.
Old Jan 21, 2005 | 12:45 PM
DAguyLS's Avatar
use lots of force and bang the **** out of it, shouldn't have a problem.
Old Jan 21, 2005 | 02:40 PM
2K_TEG's Avatar
air impact gun with phillips screwdriver attachment.
mejmp
Acura TSX
Jun 20, 2011 02:10 PM
JaeEK
11
Dec 7, 2007 07:22 PM
EJ6_MR
Dec 14, 2006 10:34 PM
gengstalllp
Honda Fit
Nov 14, 2006 04:37 PM
lke2drvgsr
Apr 5, 2004 08:05 AM
