anyone miss shift 2nd -> 3rd?
Old Jan 11, 2002 | 11:19 AM
d8168055's Avatar
Default anyone miss shift 2nd -> 3rd?
i did this again today... its been months since the last time i did it... and whats sad is that i did it at >8000 rpm!!! how do i know if the syncros are bad or my gear is chipped? hopefully it won't break down on me...
Old Jan 11, 2002 | 11:49 AM
JL 74's Avatar
25 Year Member
Default Re: anyone miss shift 2nd -> 3rd? (d8168055)
so you were in 2nd then 3rd, why would this be a misshift?
Actually, why do people misshift?
Old Jan 11, 2002 | 11:55 AM
d8168055's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (jl74)
it didnt go into 3rd.. instead, it went GGGGRRRRRRRRRRKKKKKK... ouch... man.. it hurts
IntegraT's Avatar
Do you mean 2nd -> 1st
I don't know, I've asked myself that.
Old Jan 11, 2002 | 11:58 AM
d8168055's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (IntegraT)
nope... from 2nd up to 3rd, but it didnt go in... like i said, its not the first time...
EPGONZALEZ's Avatar
the 3rd to 4th (miss) and go into 2nd is a notoriously easy miss....i bent some valves recently on that one
[Modified by EPGONZALEZ, 9:08 PM 1/11/2002]
Old Jan 11, 2002 | 11:59 AM
tjtruong's Avatar
New User
i've done it, but mainly from 2nd to third if any.. but yea it happens ..
tj
Old Jan 11, 2002 | 12:05 PM
B2FiNiTY's Avatar
I've done it a few times. Feels and sounds worse than anything in the world. Makes me cringe
Old Jan 11, 2002 | 12:07 PM
Type Goch's Avatar
New User
try changing your tranny oil(if you havent yet) also you might want to invest in some new Shift Bushigns. That might help. If the problem still occurs, i'd just baby it into gear.
Old Jan 11, 2002 | 12:15 PM
98TypeR's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (Type Goch)
that is not really a miss shift. a miss shift would be trying to go in 4th from 3rd and going into 2nd by mistake. this will throw your rpms past 10k where you will float valves and more evilish things.
I have grinded my gears a few times and its not a big deal. it happens from time to time.
nfn15037's Avatar
The 2-3 shift is easy to miss since you are trying to catch up to the motor which is rocking forward. Ive found that motor mount inserts help a great deal.
Old Jan 11, 2002 | 12:21 PM
TypeR0207's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (nfn15037)
Yeah, I botched up a few 2-3 shifts at really inopportune times .....
The worst was when I had taken Sgt off the line, and was still beating him at half track with my best ever 60', and 1/8th time ever (would have been a 13.7 run, same day I did the 13.87). F--ked up the shift, and he passed me to win. So he made it to the finals, and I picked up my $50 for making the semis ...... oh well!
Old Jan 11, 2002 | 01:16 PM
Phoenix_ITR's Avatar
were you in any sort of racing situation? maybe you just got hurried and didn't get the clutch all the way in. it sounds stupid but it happens... if the car still shifts fine, you probably don't have anything to worry about.
[Modified by delinquent, 10:17 PM 1/11/2002]
Old Jan 11, 2002 | 01:22 PM
madx's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (delinquent)
i haven't miss shift form 2nd to 3rd but i have grinded the gear severely in 1st to 2nd well what happened was i let go of my clutch before i got into gear and that is the worst i have had
Old Jan 11, 2002 | 01:31 PM
JL 74's Avatar
25 Year Member
Default Re: anyone miss shift 2nd -> 3rd? (EPGONZALEZ)
Just shift it and don't try to guide it.
Like when you go from 2nd to third, you just push it up easily and NOT try to turn it a bit right then up.
It's hard to explain. I have been driving for 11 years now and never misshifted. I have stalled the engine when I was learning but that was about it.
Old Jan 11, 2002 | 01:45 PM
IntegraT's Avatar
Uhh thanks...did you get that EP...hehe
Old Jan 11, 2002 | 09:55 PM
d8168055's Avatar
phew... thas a relief... i thought i was the only idiot to grind gears... hehe
Old Jan 11, 2002 | 11:42 PM
nEoMuGen's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (fuzznuts)
Aren't synchro the hard-to-reach = expensive labor headache?
Have anyone acutually went replacing it? How much is it labor+part?
I grind 1st - 2nd more than I grind 2 to 3rd. Maybe 5 vs 3 times.
And weird thing is that I hardly grind gears on autox/road, the most a misshift. But I grind&miss more frequently on the street...it usually happens when I am "thinking to shift fast" and the next thing you hear is ggeeekeeekeek. I guess I should rely on my instinct to shift more.
[Modified by nEoMuGen, 8:47 AM 1/12/2002]
Old Jan 12, 2002 | 12:06 AM
Mista Bone's Avatar
D Tranny Guru
ES shift bushings and rear motor mount inserts will cure this. Then all misshifts are driver error.
Old Jan 12, 2002 | 08:08 AM
EleanoR's Avatar
Default Re: anyone miss shift 2nd -> 3rd? (Mista Bone)
ES shifter bushings
I used to mis-shift in my R a lot when i first got it. You just have to practice (meaning dont shift as fast as you can all the time but get better at it over a period of time trying to shift faster and faster...you get what i mean) over and over to be able to shift smoothly/fast on every occasion. I still grind every once in a while but the bushings like i said help the feel of the shifter. When i grinded the gears regularly i thought about getting the C's short shifter thinking that the stock shifter was too long but once i got the hang of it i love my stock shifter. So smooth!
Mike
Old Jan 12, 2002 | 09:55 AM
EPGONZALEZ's Avatar
got it
rookie mistake...
Just a n00b
Acura TSX
Jul 29, 2010 04:01 PM
90teg91hatch
Jun 2, 2008 06:49 PM
civicgeek133
Aug 24, 2007 08:51 PM
Blackline47
Honda Civic (2006 - 2015)
15
Jun 25, 2007 12:41 PM
