Greddy Turbo kit BOV?????????
I have the greddy turbo kit for my 01GSR and I want to go with an external wastegate. So what do I need to do in order to convert from the internal one in the Greddy/Mitsu turbo to the external type?
Thanks in advance
[Modified by HotCompact, 7:59 PM 1/11/2002]
Thanks in advance
The only way you would be able to run an external gate on the Greddy set up would be to drill/torch/machine a hole into the exhaust manifold and weld a flange onto it...this is probably not a good idea for two reasons- first, the manifold has an internal divider that would be difficult to remove and second cast iron does not like to be welded...
BradMartin
Sep 20, 2011 08:34 AM
mike34655
Mar 20, 2004 06:51 AM
